Injector issue
Old Jul 18, 2020 | 11:15 AM
Ken Williams's Avatar
Default Injector issue
My F Type suddenly started running rough last week. Dropped it at the dealer and am told it is an injector issue. Suggested I do all three on one side of the engine. They also found a supercharger bushing in need of replacement. Cost: $3900. Anyone else have this problem? 2014 F Type Convertible 26,000 miles. Unfortunately out of warranty.
Old Jul 18, 2020 | 11:34 AM
JacksonvilleJag's Avatar
I would think a good independant shop can get you taken care of for considerably less.
Old Jul 18, 2020 | 12:17 PM
NBCat's Avatar
@Ken Williams, what DTCs are present? Is the MIL on? Is the shop suggesting you replace the injectors on Bank2?
Old Jul 18, 2020 | 07:43 PM
NBCat, the shop is suggesting that I replace one bank as it’s not much more to do the entire side than to do just one. Not sure if that makes sense. Please define DTC and MIL. Check engine light is on and it runs like crap. I’ve never run cleaner through it. Suggestions? It doesn’t get a lot of miles and there are more short trips than long just to get it out of the garage. 26k miles on it so I’m disappointed it needs such an expensive repair.
Old Jul 18, 2020 | 08:16 PM
OzXFR's Avatar
DTC = Diagnostic Trouble Code, MIL = Malfunction Indicator Lamp/Light.
Get yourself a decent code reader (such as an iCarsoft LR V2.0) to check for codes (DTCs), can save you thousands.
MIL = CEL (check engine light).
Old Jul 19, 2020 | 12:43 PM
Mahjik's Avatar
Sometimes cars not being used a lot causes more problems than actually using cars. If the car is not being driven that much, you should run some fuel system cleaner in the gas take at least once a year.
https://www.bgprod.com/catalog/gasol...ystem-cleaner/
Old Jul 19, 2020 | 01:05 PM
Nedoerr's Avatar
I did similar work recently on my supercharged XJ. An independent shop is a good idea, especially if you can find one that lets you supply your own parts. I usually save > 50%.
The injectors can be typically purchased for ~$90 each online. Installation is a couple hours on my XJ. So assuming your car isn’t too much harder, you should be able to have a shop do it for well under $1000.
If the problem with your supercharger is the coupler, as opposed to some bushing, the repair is well documented. The spring-based coupler can be swapped out for a solid oil-filled nylon type. The part is ~$20 online. You also need to buy a few gaskets (~$100-$150 IIRC). The job is pretty involved as you need to remove the supercharger. On my car it took 5-6 hours IIRC. I replaced some coolant pipes under the s/c while that was done. If your supercharger has damage to the snout from the coupler (mine did) you will need to replace the snout. This is what Jaguar always does. That part costs ~$700 online but you can find it cheaper if you look around. At your mileage it is doubtful your coupler has damaged the snout so you probably only need a new coupler.
Good luck.
Old Jul 19, 2020 | 01:23 PM
NBCat's Avatar
It seems the fuel injectors on Bank2 (cylinders 2, 4, 6, 8) are more prone to failure as they're a further distance from the high pressure pumps, which are on the other side of the front of the engine.
Use Tier 1 fuel and rotate the brands. A good way to maintain the injectors is using a product such as Techron three or four times per year.
If the vehicle isn't being driven much, keep the battery at full charge by hooking up a battery maintainer. The X351 requires a strong battery to function correctly.
Old Jul 19, 2020 | 04:07 PM
bjg625's Avatar
My local dealer has had several injector jobs done on warranty. I'ts what made me decide on the extended warranty at the time. I use BG44 twice a year in both our low mileage cars.
Old Dec 3, 2020 | 10:43 PM
Schazam's Avatar
I have the same issue right now! 3 fuel injectors failed. The dealership originally quoted me $2400 for the job but then found that the injectors had seized inside the engines cylinder head. They said it was such a big job and they would have to send it out to a machine to remove the stuck fuel injectors. They said they had to disassemble the top half of the engine for this and because its so labor intensive would be over $12000! This was for like 40+ hours of labor. Nobody had told me what caused this, but my extended warranty company (Liberty Bell) has denied the claim blaming it on flood damage incurred 6 months ago. But the dealership vehemently claims that this issue has nothing to do with flood damage from 6 months ago. If it did I would reopen my old claim with Geico my regular ins company and they would cover it. Anyway, if anyone has some advice for me it would be greatly appreciated!
XKR1985
Jun 26, 2020 06:03 PM
Twiztidunreal
Apr 11, 2018 10:34 PM
darren mckenna
Jan 16, 2015 02:09 PM
rexpo
Mar 20, 2008 02:01 PM
