Latest recall...do I have to have it done?
Old Nov 10, 2016 | 03:16 PM
buickfunnycar.com's Avatar
Question Latest recall...do I have to have it done?
Brought my car in yesterday for the 2 year service and the service advisor told me there were 2 outstanding campaign's that needed to be performed, one was K309 which was completed with a PCM software update, the other is K410 which just appeared within the last few days according to the dealer and involves a canister and a hose that turns brittle...they didn't have the item in stock and it needed to be ordered, I got the call that it arrived today.
They told me it's a rather lengthy procedure that entails removing a lot (if not most) of the interior behind the drivers seat and that it would require me dropping the car off for a few days in which they would supply me with a loaner car.
I'm not especially keen on leaving my Polaris white car with Cirrus interior in the hands of others fearing the worst and am wondering if I HAVE to have this recall/bulletin/campaign done or can I opt no.
As it is, I lined the interior with blue painters tape to prevent scuffs and marks, as I do every time the car leaves my hands...one would call me **** and rightfully so...so obviously this doesn't sit that well with me.
So the question is: can I opt out?
Old Nov 10, 2016 | 06:45 PM
Dogbreath!'s Avatar
I was able to opt out of K409 until they came out with the fix that maintained the exhaust note. Even then, my dealer wasn't forcing anything.
Old Nov 10, 2016 | 07:41 PM
ek993's Avatar
If it involves dismantling the cabin I would not be keen at all - I can just imagine rattles etc after they put it back together again - once disassembled its never going to be as tight as the original factory build.
I would also want to know exactly what the fix is for - what the component is, how critical is it to the cars operation, likelihood of failure if you opt out etc
Old Nov 11, 2016 | 06:31 PM
Nati's Avatar
I just had K410 done. They definitely were into the trim behind the seats because a couple pieces of weatherstripping are now slightly askew, and there's a tool mark in the leather trim around the seatbelt housing. They will of course be replacing that....grrr.
They said the purpose of the recall is to replace a piece of tubing that is part of the emissions system. It can apparently rot and allow fumes into the cabin.
Old Nov 11, 2016 | 06:54 PM
IRRBrogue's Avatar
Mine went in Thursday for its first service. They are waiting on a part, so I guess that is the tubing fix. Due back Monday.
Old Nov 11, 2016 | 07:34 PM
Your experience doesn't exactly leave me all warm and fuzzy...
Old Nov 12, 2016 | 01:08 PM
TR64ever's Avatar
Just picked up my car from 2nd year service and warranty work to repair a coolant leak and buzzing in speaker(s). Work was finished Wednesday, today I asked the service rep. about K410 and he looked it up: my car MY2015V6S is flagged for it, but the work wasn't done because it wasn't flagged until after they finished with my car.
K410 relates to "canister & hose" behind the driver's seat, ozone degrading the hose.
The coolant leak was my first problem in 20 months of ownership ("rear crossover pipe leaking" and replaced). I had buzzing in speaker(s) called out at YR1 service, but never went back for the speaker(s) installation as they had to order the parts.
I will add: the fix - new speaker(s) installed this week (PS sub and door?) -- the Merridian Sound System has NEVER SOUNDED THIS GREAT! Then I turned off the radio and listed to the motor & exhaust sing, as usual....
Old Nov 12, 2016 | 04:29 PM
Frenchy's Avatar
Default recall, TSB, "campaign"?
Is K409 a recall, in which case all affected car owners must be notified, or a TSB (technical service bulletin), in which case they might mention it when we bring in the car for the next service?
Another question: Is there an identifier other than K409 which, when clicked, gets me to AutoAnything.com?
Old Nov 13, 2016 | 06:10 AM
Unhingd's Avatar
The two TSBs are K309 and K410.
Old Nov 13, 2016 | 09:43 AM
Greggbhill's Avatar
I had my 2016 V6S in yesterday for 1 yr service and the "campaigns" they prescribed were K405 (flash to fix errant maintenance indicator light) and K410 (hose/canister thing). They did K405 but had to order parts for K410.
Old Nov 14, 2016 | 01:45 PM
SinF's Avatar
Could anyone post K410 steps to give me a better idea what is involved?
Old Nov 14, 2016 | 02:43 PM
Arne's Avatar
I think the K410 is for the US market only? As far as I have managed to find out, it does not seem to apply for European models. Is the canister in any way related to emissions and/or environmental issues?
Old Nov 14, 2016 | 03:29 PM
Nati's Avatar
Yes that is specifically what it's for.
Old Nov 14, 2016 | 03:50 PM
Arne's Avatar
That could be the reason why it seems to apply only for US models - different regulations. That canister and hose might not be parts included in European models (if they are not essential for "normal operation")?
Old Nov 15, 2016 | 01:58 PM
Uncle Fishbits's Avatar
2016 Manual... I've not heard of these or seen note of them from Jag. I hadn't been told this had been done during prior services / clutch fix. Is this for earlier models?
Old Nov 15, 2016 | 02:21 PM
Mine was an ordered unit and a very early build...see my signature, arrived 10/24/14
Old Nov 15, 2016 | 02:54 PM
enfield's Avatar
I am hoping I don't have this canister K410 in my Canadian car....
Old Nov 15, 2016 | 03:47 PM
Nati's Avatar
And mine was one of the first 2017s built for the US. So yeah. Appears to be - all of them.
Old Nov 15, 2016 | 04:34 PM
Unhingd's Avatar
I'll wait until I smell gas to get it done. Emissions related stuff is warranted for 10 years, 100k miles.
Old Nov 15, 2016 | 04:42 PM
Right there with you, I'm passing, let the dealer handle it when I turn it in next October...
