Leak from diff sensor
Old Jan 13, 2020 | 05:18 PM
Alasdair 63's Avatar
Default Leak from diff sensor
I have a small leak from the 2 wire diff sensor, is this a temperature sensor, only noticed it when I removed the plastic cover
Old Jan 13, 2020 | 06:31 PM
Nati's Avatar
A leak of what? Gear oil?
The pinion seal is known to leak and require replacement. Is it possible you're just mistaking the source?
Old Jan 14, 2020 | 06:16 AM
Default Diff sensor leak
Leak inside sensor pocket
Old Jan 14, 2020 | 10:53 AM
Terrance39's Avatar
I just recently had to pull the motor off the diff and reseal the mounting plate. That's where I think your leak is coming from. Your leak is coming from slightly above according to your pic. Not a bad job. Just drop the rear brace and lower the muffler. Filled it back up with redline fluid. Give the gasket sealant and hour before you torque down the bolts, before that put the bolt in finger tight. They allow it to sit for 24 hours before adding back any fluid.
Honza1
Jan 28, 2024 06:55 PM
nonsns3
Jun 16, 2020 04:50 PM
oceanreef
Mar 30, 2016 02:42 PM
Clayton Webb
Oct 26, 2015 10:56 PM
roger ele969c
XJ40 ( XJ81 )
Jun 10, 2011 05:52 PM
