Locking Wheel Nut Torque
Old Nov 15, 2015 | 04:46 PM
Unhingd's Avatar
Default Locking Wheel Nut Torque
When pulling the wheels off my car today, I noticed all the locking nuts had been tightened down at a significantly lower torque than the others which were at the specified 92 ft-lbs.
Does anyone know what the locking nuts should be torqued to? I presume the key pattern can't handle the full torque.
Old Nov 15, 2015 | 05:36 PM
Unhingd's Avatar
I went ahead and torqued to 92 ft-lb. I suspect that the last shop that had them, didn't want to hit the key with a calibrated air impact wrench.
Old Nov 15, 2015 | 05:45 PM
Buckingham's Avatar
I torqued them to 92. No problem. My key fits around the lock so no chance of slipping and stripping the lock. MacGuard keys fit into the lock and can easily be damaged by excessive force. As far as I can determine, only JLR makes a lock that fits our wheels.
Old Nov 15, 2015 | 05:54 PM
Unhingd's Avatar
+1. The JLT key does indeed offer a solid connection with the nut.
Old Nov 15, 2015 | 06:47 PM
lizzardo's Avatar
I too noticed that the locks were nowhere near the specified torque. I don't trust "calibrated impact wrenches" in any case. I always tighten the lugs with a proper torque wrench.
Old Nov 15, 2015 | 07:01 PM
Unhingd's Avatar
+1.
Old Nov 16, 2015 | 09:05 AM
Desert Hiker's Avatar
Default MacGuard.......
........can be torqued to 92 ft-lb with no problem using an adjustable/calibrated torque wrench with a bit of due care: keep the wrench properly aligned with the wheel and maintain some inward pressure on wrench to keep the key fully engaged.
Desert Hiker
Old Nov 16, 2015 | 09:46 AM
Foosh's Avatar
No impact wrench ever touches any of my cars. I even take my own calibrated one to the tire shop with me.
My Lotus once had several lug bolts seized because some gorilla had massively over-torqued them at one point in it's life. They had to be drilled out.
Old Nov 16, 2015 | 02:23 PM
F-typical's Avatar
Ouch...
andrewno1
Mar 4, 2019 04:48 PM
jaguarxjl
Nov 6, 2015 04:46 PM
jagtoes
Nov 6, 2015 09:53 AM
Topsales1
Oct 30, 2015 02:39 AM
