Looking for other modifications that will increase mainly Torque.
Old Nov 1, 2018 | 10:59 AM
  #41
FType17's Avatar
Originally Posted by Khwaledd
the e-diff came on before I ever even went to the track, it’s been about 2-3 weeks now with the ediff unavailable problem.
Dealer visit...
Old Nov 2, 2018 | 01:08 AM
  #42
ss23's Avatar
Originally Posted by FType17
I opted to up the rev limiter to 7200RPM, but it can go a tad more. This results in increased power (power is a function of torque and RPM)
Did you tune the TCU as well or are you shifting manually in sport?
Old Nov 6, 2018 | 10:22 AM
  #43
FType17's Avatar
Tweaked the TCU as well but I drive in manual 99% of the time
Old Nov 6, 2018 | 08:56 PM
  #44
ss23's Avatar
Can you provide any tunes for the TCU remotely? I think there would be a lot of us, with ECU remaps and tunes, who could benefit. Hoping it can be done through the OBD II port!
Old Nov 6, 2018 | 09:31 PM
  #45
FType17's Avatar
I worked with ZF to modify the TCM and that was along with a 900Nm upgrade. You can slightly decrease the shifting time, on the V8 WITH a 900Nm transmission, you can then enable launch control but realistically unless you increase the rev limiter, there is no real point in tweaking the TCM. I only increased the rev limiter because I was confident that the decrease in rotating/reciprocating mass, the increase in bore leading to a supersquare engine allowed it safely.
I believe that VAP was working on this, I would reach out to them if they provided you with tune etc.
Old Nov 6, 2018 | 09:50 PM
  #46
ss23's Avatar
Thanks for the response, I believe VAP increase the rev limiter in all of their tunes to about 7,000 RPM. My objective would definitely be to just take advantage of that when driving in auto, not really about the shift times. Will follow up with VAP though
Old Nov 7, 2018 | 03:08 PM
  #47
Unhingd's Avatar
I have successfully remapped the TCU for my MT to take full advantage of the increased rev limit.
Old Nov 10, 2018 | 03:46 AM
  #48
F-typical's Avatar
The most cost effective way to increase Torque at the wheels is to use a lower gear.
Old Nov 10, 2018 | 07:48 PM
  #49
Mpowerr's Avatar
I use https://www.jet-hot.com/ real pros, no BS. Ultra 2500 will do.
Going with Cell 100 cats helps also if one wants to keep cats (mandatory in many states for emission visual inspection). ECU Tuning is required to maximize the benefits and keep the CEL off.
Water/meth injection helps also with cooling, not only to aid in pre-ignition detonation. As a side benefit you also get clean intake valves. I use the Snom MAF/MAP controller unit from Snow Performance. All you will need is two small holes in the upper intake manifold cover and tap the holes.
---- SIDE NOTE for V6 owners ---
I have been reading of people swapping out mid-pipes with ones having an X pipe or with the one from the V8. DON'T! Not only it brings no benefit in terms of power to a V6 but it actually increases the exhaust temps. On V6 engines, the single best way to evacuate hot exhaust is to swap out the muffler with straight pipes (and they sound nice), not raspy as claimed.
where did you put the tank for your water/meth and how big is it?
robaroni
Jul 19, 2017 09:01 AM
REDTYPE
Sep 28, 2015 12:08 AM
al_roethlisberger
Sep 30, 2014 04:50 PM
JagV8
Sep 11, 2013 12:02 PM
weisberg
Oct 9, 2012 11:54 AM
