Looking for plugs that connect rear wiring
Old Nov 12, 2020 | 11:34 AM
MatthewMG's Avatar
Default Looking for plugs that connect rear wiring
Hi, does anyone know the numbers of those plugs? I need their numbers to buy them - I marked them on picture. Unfortunatelly, mine Jaguar has them cut (as on picture).
F-Type 2013, V6 Base 340HP, USA
My car
YouTube Screen
Old Nov 13, 2020 | 01:21 PM
Rummy636's Avatar
Jaguar doesnt offer connectors only. You have to get harness to replace plugs. I would find a junkyard car or install your own connectors.
Old Nov 14, 2020 | 05:22 PM
xmo's Avatar
xmo
They look like off-the shelf parts. I suggest you ask on an electronics forum like eevblog
Folks there can also advise on an appropriate crimp tool.
https://www.eevblog.com/forum/index.php
Old Nov 17, 2020 | 02:49 PM
xdave's Avatar
Whilst some connectors are classed as 'unserviceable', most are and you can buy replacement connector housings and pre-terminated wires to make repairs. The middle green and black connector are definitely available to buy from JLR parts as they are connectors used for 20+ years now. I'm not sure about the 8 way green one but normally unless they are specialist connectors like high speed data or AV ones then they are available.
I'm not intimately familiar with the F-Type wiring so I don't recognise that harness. If you could reply with the fitted location (left hand side of the trunk?), and/or the long XXXX-XXXXXX-XX number printed on the label I can look it up and see if the parts are available. If you can't get a harness number, then do you at least know what one of those plugs connects, or one of the circuits that runs through it as I can look up those to locate them?
Graham Sears
Feb 4, 2020 09:16 AM
Simon99
Aug 22, 2019 08:01 AM
Qvhk
16
Jul 18, 2018 09:36 AM
OriginalCaruso
Jan 1, 2017 08:58 AM
Leonard_85
28
Aug 30, 2012 07:09 PM
