Loose Change Sound Over Bumps
Old Jun 21, 2022 | 02:56 PM
Iticip's Avatar
Default Loose Change Sound Over Bumps
Hello, I have a 2015 Type R with 100k miles (woohoo!)
I’ve noticed a sound recently when going over bumps.. there’s something that sounds like loose change or keys, possibly a loose bolt coming from the left tire area.
nothing seems poor about the ride quality, but curious if this rings a bell for anyone.
Old Jun 21, 2022 | 04:54 PM
DJS's Avatar
DJS
The active exhaust vacuum pump is behind and inboard of the left rear tire, you might take a look to see if anything's loose. But no, your description doesn't sound familiar.
Old Jun 21, 2022 | 06:57 PM
Mbourne's Avatar
Did you check for loose change? Sorry could help myself It could be a loose connector for the wheel well liner.
Old Jun 21, 2022 | 09:31 PM
Iticip's Avatar
hm, that sounds like a really good assumption. There’s actually a slight buzz sound from the left side exhaust too.
Old Jun 22, 2022 | 05:17 AM
dibbyandco's Avatar
Could be any of those, or maybe some loose baffles in the exhaust. I get exactly the sound you describe on start up when the tickover revs are higher, and the noise fades when the revs drop off. Don't hear it thereafter
Old Jun 1, 2023 | 04:43 PM
KimboSlice's Avatar
Did you ever get this sorted out?
I get this exact same sound going over speed bumps. Sounds like a handful of loose bolts rattling around in the rear of the vehicle but only when going over significant bumps and no other suspension issues or noises.
jomo
Apr 5, 2022 01:04 PM
iownme
May 10, 2021 07:29 PM
Dell Gailey
Aug 23, 2018 03:07 PM
Joanie
Sep 26, 2014 11:51 PM
Striker27
Aug 12, 2010 03:36 PM
