Lowering F Type
Old Dec 17, 2015 | 12:30 PM
2013XK's Avatar
Default Help! How low is too low?
I just lowered my 2013 XK with the H&R springs. H&R's website says the springs lower approx. 1.3" but the suspension shop who did the work says it dropped 1.6". Now I have the adaptive dynamic mode fault code on the dash and the dynamic mode does not function. The dealer cleared the code but it came back. Does anyone know if the 1.6" drop was too much? Would spacers help? Anybody else have the same issue with their F Type?
Old Dec 17, 2015 | 03:18 PM
Unhingd's Avatar
You might be better off asking someone on the XK forum. However, if H&R says 1.3", they generally mean it. You should contact them directly with your issue. You may have received the wrong springs. The 1.6" could well be an issue if the sensors are detecting movement beyond some preset limits.
Old Dec 17, 2015 | 03:32 PM
Cambo's Avatar
I recently learnt that yes the height sensors on these late model cars are also part of the Dynamic Stablity Control system (in past models it was only for the headlamp leveling) so if the car is too low after fitting new springs then you get these sort of faults.
The DSC height measurement can be re-calibrated with the IDS/SDD diagnostic system which should clear these errors you get. (I found the function in the SDD while I was working on something else).
In fact even if your car is not showing any errors after lowering, I would suggest to get the height re-calibrated anyhow.
Old Dec 29, 2015 | 05:58 PM
Stuart@VelocityAP's Avatar
Originally Posted by Unhingd
H&R will lower by 1.25" and Velocity AP will lower by .75". Both claim to have fully progressive springs, but both seem to imply the other does not. Go figure.
To the best of my knowledge, our springs are the only type available that offer a tapered rod design in X5 Steel. I'm not sure at what point we can all call our designs 'fully' progressive, but we do offer an additional design feature which has been reported across multiple F-Type platforms, as well as Aston DB9, V8 Vantage, and Sportpack cars to have excellent ride quality despite lowering.
We currently have these on sale until the 31st - email me Stuart@VelocityAP.com for details
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old Dec 29, 2015 | 06:43 PM
Unhingd's Avatar
The H&R spring wire is not only coiled to a smaller radius at the top, but the wire seems to narrow as well. Might have been an optical delusion.
With the H&Rs, ride quality on dynamic setting is just a bit firmer than the OEM springs, but very smooth. However, on the standard setting the ride is a bit jittery, and obviously under-damped. I don't think anyone will be disappointed with either the H&R or the VelAP springs.
You do, however, need to assess whether you will have enough ground clearance to traverse your typical paths of travel. The 1/2" difference between those two options could be huge. Some folks even note inadequate ground clearance with the OEM suspension. I, however, have so far not encountered any clearance issues with the H&Rs despite all the DC area speed bumps I cross. The big problem seems to be for those with steep driveways and garage ramps.
Old Dec 30, 2015 | 07:13 AM
strippersteel's Avatar
2013XK I haven't heard of anybody getting that code so like Unhingd said perhaps you received the wrong springs.
Also not to hijack the thread but Unhingd do you have any pictures of your F Type lowered?
Old Dec 30, 2015 | 10:14 AM
Unhingd's Avatar
this post shows both the before and after pics:https://www.jaguarforums.com/forum/f...8/#post1372181
Old Dec 30, 2015 | 01:50 PM
  #28
Thanks Unhingd and that drop with wheel spacers looks perfect! Nice ride buddy.
Old Jan 8, 2016 | 07:57 PM
Unhingd's Avatar
I have to take back what I said above:Lowering F-Type
For the base and S cars (incl. V8S), H&R claims a 1.2" drop (1.3" for the R, different spring set).
This is what mine actually measured:
Rear:1.5"
Front: 1.375" (front wheel well still .25" lower than rear)
No tire rub under severe cornering and braking.
No (additional) bottoming-out issues (though, I do take speed bumps more slowly than before).
No error codes.
Highly recommended if you don't use technical climbing gear to ascend your driveway.
Old Jan 8, 2016 | 08:33 PM
  #30
BMo's Avatar
BMo
Very useful info...thanks. I'm still waiting for Stuart to assess specifics to lower 2016 R convertible and think I want a less aggressive lowering spring.
Old Jan 25, 2016 | 12:47 PM
  #31
Our F-Type Springs are out!!!
https://www.jaguarforums.com/forum/f...9/#post1389285
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
rvdz
Dec 7, 2019 06:42 AM
bigdhenderson
23
Aug 27, 2016 06:19 AM
felinecat
E type ( XK-E )
Jul 31, 2015 01:43 PM
gsaenz84
Aug 29, 2014 09:38 AM
