Lowering Springs Install Help
Old May 7, 2019 | 11:09 PM
VeeDub's Avatar
Default Lowering Springs Install Help
Hey guys, I recently took on the project to lower my F-Type V6S. I bought the Eibach kit and I have finished installing and will tackle the fronts next weekend. Two things I ran into was that the spring is not rotated against the spring perch stops. Also when I install the strut, I had to push down on the lower control arm with a decent amount of force (had to ask for other persons help while I push the bolt in) and push the strut inward. Did anyone else run into these problems if these are actually problems?
Old May 7, 2019 | 11:45 PM
OzXFR's Avatar
Yep, on the rears you need to push the control arm down with lots of force (most use a large pry bar and lever it down) to get the bolt in, this is normal.
Also a tip for the fronts - the strut and spring assembly won't come out (and the new won't go in) unless you undo and move out of the way one or two control arms / suspension components, again a pry bar comes in handy.
Disclaimer - I haven't done this myself but I have watched while a mechanic did it.
Old May 8, 2019 | 01:13 AM
VeeDub's Avatar
Great! Thanks for confirming. Did you guys have to preload the bushings and suspension by tightening the strut bolts when the cars on the ground?
BLKCAT13
Aug 4, 2016 04:58 AM
Yurikaze
Mar 8, 2010 01:10 PM
Florida Phil
Oct 10, 2008 12:40 AM
DeepSix
Dec 23, 2007 12:53 PM
