Makes me sad to see this.
Old Dec 5, 2023 | 09:01 AM
rsqrd930's Avatar
Angry Makes me sad to see this.
In Pittsburgh over the weekend, and saw this in a parking garage. I hope if this person is on the list, or whatever, that they somehow found the person that did this.
If that person is on the list, maybe give me some closure. I suspect there is no 'major' damage and once repaired will be good as new.... hopefully...
Old Dec 5, 2023 | 09:10 AM
cpq100's Avatar
Another reason to run a dashcam with a parking mode.
Old Dec 5, 2023 | 10:28 AM
CJSJAG's Avatar
Would not be surprised if it was even intentional!!
Unfortunately, our cars do not always get viewed favorably.
Old Dec 5, 2023 | 10:45 AM
Zaguar's Avatar
Is it possible the accident happened elsewhere, and it was towed home while insurance takes it's time to sort out repairs?
Old Dec 5, 2023 | 03:21 PM
BruceTheQuail's Avatar
(puts on accident investigator hat) - Possible, however the debris field under the vehicle would suggest that the incident occurred at that location.
Anecdote, back a number of years ago I read an investigator's report in a serious accident, in which there was an allegation that an oncoming car had its high beams on which then blinded the other leading to a head on collision. So anyway aside from questions about the debris field (bigger, heavier bits end up much further away than small particles, which makes sense when you think about it), there was evidence of glass/plastic particles fusing on to the low beam bulb but not the high, essentially establishing that high beams weren't on. It was just one of those things that never would have occurred to me, quite fascinating.
Old Dec 5, 2023 | 03:49 PM
CJSJAG's Avatar
Looks to me that the car was wacked where it is standing in a commercial parking garage, presumably by something large backing into it vigorously.
This was not a light tap!!
Old Dec 6, 2023 | 12:37 AM
Michael211's Avatar
IMHO the photo suggests the damage was done by someone backing out of the space next to it on the driver's side. Look for a car with front driver's side fender damage. then match the swapped paint.
Old Dec 6, 2023 | 10:21 AM
Valerie Stabenow's Avatar
Default Just sickening to look at
I have (probably) a nearly identical F... 2017 Ammonite Grey coupe. I agree with Michael211, looks like the offender caught the left front fender panel and ripped it off. Not sure what happened to the broken out sections, unless those pieces are what are under the front lip. Aren't there usually security cameras in these parking garages? I would hope so and that this was caught on camera. The ONLY positive on this may be that the headlight assembly may not have been hit ($$$$$) and the plastic front pieces can be replaced. NO EXCUSE for doing this and running off. Just more confirmation to continue parking in out of the way spots as much as possible. Hadn't thought about a dash cam, and was not aware of a 'Parking Mode", but that would be something to research.
Old Dec 6, 2023 | 10:56 AM
cpq100's Avatar
Basically what parking mode does is record anyone or anything near the car that is moving while the car is parked.
Old Dec 6, 2023 | 11:10 AM
PaulBarrrera's Avatar
Unhappy
I had a 5mph kiss from someone who pulled in front of me last summer and busted one headlamp. They repaired the nosepiece and replaced a few small parts and of course, paint. The bill was $12K. The used headlamp was $1650. a few weeks later my driver's side headlamp had a bad DRL and was replaced under factory warranty. The dealer invoiced Jaguar $6316.00 for parts and Labor!!!!!!!! The lamp was $6036.00. Holy ****!
Old Dec 6, 2023 | 02:54 PM
synthesis's Avatar
Originally Posted by PaulBarrrera
...a few weeks later my driver's side headlamp had a bad DRL and was replaced under factory warranty. The dealer invoiced Jaguar $6316.00 for parts and Labor!!!!!!!! The lamp was $6036.00. Holy ****!
THIS is the sort of thing that kills a car brand.
kb58
Jun 14, 2022 09:25 AM
DGL
Oct 1, 2019 10:55 AM
Jeep2Jag
Non-Jaguar Vehicles
Oct 8, 2014 01:19 PM
mjlaris
Oct 18, 2011 09:06 PM
DB6
Feb 19, 2011 02:43 PM
