Manual Transmission Question
Old Jul 29, 2021 | 12:47 PM
evilftypedw's Avatar
Default Manual Transmission Question
Has anyone with a manual transmission tried a Spec Performance Clutch? Mine's got a first Gen clutch and thinking about this vs the latest OEM clutch: https://specclutch.com/applications/...016&type=13925
Old Jul 29, 2021 | 01:23 PM
SinF's Avatar
I have not read about anyone installing non-OEM clutch and the latest generation of clutches seems to be holding as long as both clutch and flywheel are correct parts.
From what I learned going through 1st, 2nd and 4th gen clutches is that too-aggressive clutch (like second gen clutch) has a chance to destroy fragile LSD. If you chose to go with performance clutch consider further customizing your drive train to include driveshaft flex disc.
Old Jul 29, 2021 | 05:31 PM
Unhingd's Avatar
I have a Spec Clutch and single mass flywheel sitting on a shelf waiting for a Gen 4 clutch to fail. I sent Spec the OEM units to help design their units. @JDD2017 has just installed the Spec clutch and flywheel. Perhaps he can give us a review.
Old Jul 29, 2021 | 06:39 PM
I would definitely be interested in hearing that review.
Old Jul 29, 2021 | 09:35 PM
Valerie Stabenow's Avatar
Yes, would also like to read that review. the MY2017 I have now has the 4th gen clutch. I've put on about 3500 miles since install, don't do crazy things or track it, so hoping it lasts as long as my 98 Honda Civic's did (370,000mi) But then, who am I kidding. LOL and falling on the ground.
Old Aug 1, 2021 | 07:35 PM
HermanWiegman's Avatar
@evilftypedw
i would be interested in the progress of this swap.
Can you discuss what you are thinking?
1) what is the intended torque rating of the clutch system? (pressure plate holding force, and friction disk material)
2) what is the selected flywheel material or mass change? (lighter can give quicker RPM changes, but also risks poor idle and stalling)
3) how much is the drivability impacted? (a friction disk with impact springs takes the edge off of torque impulses)
My 2017 has the original clutch which did slip when I purchased my car used last fall (abused by previous owner?), but so far it hasn't acted up on me (I am gentle on clutches), so I am happy for now.
Unhingd
Nov 5, 2025 08:45 AM
HermanWiegman
Mar 21, 2021 01:06 PM
car5car
Mar 12, 2019 06:17 PM
Mgbams
May 14, 2017 01:46 PM
Unhingd
May 27, 2016 08:39 PM
