Michelin Sport 4S vs MPSS
Old May 3, 2018 | 02:50 AM
  #181
diplomat's Avatar
It is maeasured from the moment when I released the brake pedal and I measured 0-100km/h, so 0-60 mph is even better, but of course some GPS timing equipment would be better.
This was with Pirelli PZERO which have very bad traction.
I think with Michelin Pilot Sport Cup 2 and Crank Pulley + ECU Tune I should be able to make 0-60 under 4 seconds.
Old May 3, 2018 | 03:08 PM
  #182
UBI's Avatar
UBI
The 100 km/h on the speedo are not real 100 km/h!!! ;-))
Old May 3, 2018 | 03:13 PM
  #183
diplomat's Avatar
Sure! Everybody knows that, but still the time for 0-60 is less than 4,3 s and that is less than what Focus RS does and that was my point.
Old May 3, 2018 | 04:21 PM
  #184
FR500GT's Avatar
Originally Posted by Cherry_560sel
I haven't dyno'd since installing the spray kit so its not official, but I was hovering around 475 hp with the other mods and I am jetted for a 175 hp shot distro.'d from 2800 RPM through 6500 RPM. Simple math tells me I am probably in the 600HP+ ballpark. First gear launches are pure heaven now. I start with a 20% hit and build up progressively through the first six gears. Don't know how much the 3.0 liter can take, but so far so good
Howe long have you been running at 475hp on your 3.0 V6?
Old May 3, 2018 | 09:08 PM
  #185
Unhingd's Avatar
With 305/30-20 tires, the F-Type speedo reads true.
Old May 3, 2018 | 10:47 PM
  #186
Cherry_560sel's Avatar
I think I ordered the tune from VAP around December of 2016 and the pulleys got installed around March of 2017...So I would guess I ran with those mods for about a year before installing the spray kit. Got the MPS4S tires in March of 2017 also.
Old May 4, 2018 | 01:07 AM
  #187
FR500GT's Avatar
Good to know that it’s holding the power well!
Old May 4, 2018 | 09:24 AM
  #188
UBI's Avatar
UBI
With 20" 295 the difference are about 4km/h. PerformanceBox vs Speedo!
Old May 4, 2018 | 06:17 PM
  #189
bjg625's Avatar
Retiring P-Zero's after 4.5 years and 16k miles. PS4S due in Wed. On 19's you can only go up 1/2 inch on rears so for $11 I said why not. Will update after install.
Old May 5, 2018 | 04:10 AM
  #190
jaguny's Avatar
Are you going installing the rears (assuming 305's) on oem 10.5 inch wheels?
Old May 5, 2018 | 06:25 PM
  #191
bjg625's Avatar
going on original wheels, problem was Michelin has yet to make a wider size that fits. Did a little after we reference michelin dealer site. They just don't have it yet. i think more options for 20's.
Old May 5, 2018 | 11:34 PM
  #192
Four years !!! wow...
Old May 7, 2018 | 07:36 AM
  #193
Selko92's Avatar
Before I get myself some Michelins I will burn up these P -Zeros and be done with them.
Old Jan 4, 2019 | 03:03 AM
  #194
4Holer's Avatar
PSS 305’s on the back, 265’s up front. A lot stickier and quieter than the original Pirelli’s.
Old Jan 6, 2019 | 05:20 PM
  #195
Tpaxc's Avatar
Has anyone run 295/25/20 on the rears? Curious how the height difference would look?
Old Jan 6, 2019 | 05:57 PM
  #196
Unhingd's Avatar
that will be over an inch smaller diameter. To look right, you would need to under size the front tires as well. Also, the diameter difference front to rear would cause serious issues on the AWD cars.
Old Jan 6, 2019 | 08:23 PM
  #197
Tpaxc's Avatar
Ah ok. I have a 2015 RWD
Old Jan 10, 2019 | 09:39 PM
  #198
OpenF's Avatar
I've had the P4S's for about 14 months and almost 14K miles (~22.5K KM). They should probably last another 3-5 months with a corresponding 3-5K miles before I need a new set. The question then is going to be getting a set from one of my local-ish Jaguar dealers, like last time, or from tirerack.
Old Jan 10, 2019 | 10:43 PM
  #199
OzXFR's Avatar
Why are you even thinking about where to get them from?
Log on to the Tire Rack site and check out their prices, then get a quote from the dealers for the exact same tyres, and then go with whichever is cheaper.
I will bet that the Tire Rack prices are significantly cheaper than the dealer prices, although you need to factor in the fitting cost as well (and maybe the Tire Rack shipping cost if any also).
Old Jan 11, 2019 | 01:18 PM
  #200
Unhingd's Avatar
The dealers may not be able to compete with TireRack, but a good indy performance tire shops should be able to match those numbers after you factor in the M&B costs.
