Anyone used Monroneylabels.com? I thought it would be cool to get a window sticker for my new-to-me 2016, but the label they generated shows only a base car and does not include some options that I am pretty sure I have. Thanks!
I can make a window sticker / Monroney Label with Jaguar specs/format/font/style. Same as original.
Below are how it looks digital format and printed. For the printed one Owner asked for it without some of the black borders. $110 including shipping printed in high quality 80# paper in matte or glossy finish
The Monroney printed out for this car seems to be spot on. I've had the car almost 5 years and think I've found or figured out most of it. It came with a 'virtual' CD player in the console, which I did not see until a couple of years ago. Not cited under the 770 Meridian entry, though it may be considered part of the Infotainment system.
Here's a link to 'owner's manual', in case you did not get one:
Wow, those are really nice! Are you able to do a more basic version? I just want to confirm the options on my car and dont need the original sticker replicated. Thanks!
I ordered for kicks.
Colour of car was wrong, and it's missing some options.
If you just want to confirm the options on your car, can you just get a topix vehicle summary?
I contacted jaguar, had to prove ownership then they emailed me the list of all things included on the car. And for free.
I suspect your dealer could do the same
I have found Topix to be unreliable, many members have reported across multiple forums that the Topix "build sheet" often contains errors.
Including options the car does not have and/or not showing options it does have.
AFAICT the Topix build sheet is accurate about 90% of the time so inaccurate about 10% of the time.
No. I can only create them by taking the info from a build sheet or window sticker printout. think any Jaguar dealer should be able to print a build sheet out for you and lookup what packages/options your F-Type came with.
But it is just the list from TOPIx which others have said is inaccurate (I'll have to check mine again). Suprising that jag cust service would use a source that isn't correct.
