Motorized front plate - worth it?
Old May 10, 2017 | 05:57 AM
XFactoR's Avatar
Default Motorized front plate - worth it?
My plates are in for my SVR, but I'm balking at the idea of putting a front plate on. It's black and looks so sinister without anything there. That said, I had one on my R, and to be honest, I never noticed after a while.
I can't drive around without one completely because I'm just not in the mood to be pulled over for stupidity. I've been researching the different solutions and the motorized plate option is interesting....but it seems that when the plate is up, it covers the air intake in the front diffuser...it has to disrupt airflow for which the SVR especially is specifically engineered.
So, would you guys just get the front plate and put it on in the normal position affixing it to the bumper but not disrupt the airflow to the underbody OR would you explore the motorized plate option?
Old May 10, 2017 | 06:05 AM
Mulmur's Avatar
I had the motorized plate on my XKR, but it wouldn't install in a reasonable way on my FtypeR, so I used earth magnet for the F plate.
Although I am not able to drop or raise the plate while driving now, I can easily pull it off for cleaning or when I drive in locations that don't care about the front plate.
Lawrence.
Old May 10, 2017 | 06:36 AM
XFactoR's Avatar
Interesting....did you DIY or get someone to install it for you?
Old May 10, 2017 | 07:22 AM
Unhingd's Avatar
As of a year and a half ago, none of the motorized options fit anywhere on the F-Type. The best option is the quick release Sto 'n Sho:
STO N SHO 2013-2017 Jaguar F-Type
Old May 10, 2017 | 08:43 AM
stmcknig's Avatar
+1 for the Sto N Sho. Its that quick to add/remove that I can't see the point in trying to add all the mechanical electrical gubbins to go wrong ;-)
Old May 10, 2017 | 09:47 AM
DPelletier's Avatar
+2 on the Sto N Sho.
Dave
Old May 10, 2017 | 07:11 PM
Mulmur's Avatar
Jaguar mechanic friend did it.. but it was easy.. he used epoxy behind the center grill bar and glued a length of metal and then attached earth magnets to the back of the plate, simply held with industrial tape across.
Finished product looks like a standard bolted on front plate. I like the location better than what I would have ended up with using the sto-go bit.
If you are interested enough I can find a picture of it and send.
Lawrence
Old May 11, 2017 | 06:48 PM
Mulmur's Avatar
Picture of placement.. early days, plate now has a frame..
Lawrence
Old May 11, 2017 | 07:35 PM
XFactoR's Avatar
Default New complication
Okay, it seems that my 2017 SVR has a special laminated windshield that my 2015 R did not have ....which means that my EZ Pass does not read through it. It reads 1 out of 5 times through the glass...
I think I have no choice but to mount the front plate so that I can mount the EZ Pass on the bracket .... 😑
Old May 11, 2017 | 08:05 PM
Nati's Avatar
Did you put your EZ PASS transponder in the cutout area of the windshield (the dots)? It should work fine in that area.
Old May 12, 2017 | 01:09 AM
Misujerr's Avatar
Do you have the heated front windshield? Wondering if the filaments block the signal. I have it but haven't used my transponder on this car yet.
Old May 16, 2017 | 10:34 PM
XFactoR's Avatar
Default Did it...
Thanks for your comments on the EZPass ...it does work in the upper dotted area. That's all I needed so I got the motorized front plate installed. It's cool, and looks good. I'm happy that I didn't drill into my bumper ....
Old May 16, 2017 | 10:37 PM
Unhingd's Avatar
Pics please.
Old May 18, 2017 | 12:14 PM
Dremorg's Avatar
Vid please
Old May 18, 2017 | 01:12 PM
Burt Gummer's Avatar
On the bumper is hideous. Motorized is too low. Sto-N-Go Mike is the license plate hero.
Old May 18, 2017 | 01:27 PM
Senninha's Avatar
Also have Sto'n'Sho, nicely made product, but accept that for the SVR you have extra considerations given the bespoke aero on that model
