MY 2021 grille retrofit?
Old Jul 31, 2020 | 08:43 AM
tec-9-7's Avatar
Default MY 2021 grille retrofit?
I know it's probably a bit soon, but does anyone know if the new no-bar grille will retrofit into an earlier F-Type? This is a cosmetic mod I would definitely consider.
Old Jul 31, 2020 | 08:54 AM
Unhingd's Avatar
Absolutely not. Totally different shaped nose opening. Your only (expensive) option is to replace with a Project 7 grille and surround.
Old Jul 31, 2020 | 10:56 AM
tec-9-7's Avatar
Figured as much - no thanks on the expensive option!
Old Nov 17, 2022 | 05:35 AM
hercesq71's Avatar
Default Project 7 Grille
Does Anyone know where I can get a project 7 Grille? All efforts have failed.
Old Nov 17, 2022 | 04:56 PM
Therock88's Avatar
I do not think they are available any longer...Unless you find someone who has one, and is looking to get rid of it.
DC
Old Nov 17, 2022 | 09:57 PM
hercesq71's Avatar
Default P7 grille
[that’s terrible news! Any other option for getting rid of that horizontal bar in the middle of the grill?
Old Nov 20, 2022 | 01:17 PM
Michael211's Avatar
I'm considering fabricating a new grill for my 2017 out of material like this. It should be fairly easy. I think it would be simple to use the S badge or growler to create a removable "cap" over a hole to accommodate the tow hook. Black Pack fans might prefer balck material, but I'm a classicist. Your thoughts?
https://www.twpinc.com/wire-mesh-by-...esh/alpha-mesh
Old Nov 20, 2022 | 09:40 PM
cujet's Avatar
People have been making grills from metal screen for well over a century. It looks pretty good and provides adequate protection. However, it does restrict airflow somewhat, not necessarily a bad thing, if cooling drag is an issue. (note: cooling drag exists due to the need to naturally force air through the radiator)
Other grill materials include a honeycomb like material, which is generally less restrictive. It's available on Ebay and other sources.
Old Nov 22, 2022 | 12:25 AM
Michael211's Avatar
Do we think that honeycomb shaped material flows better because that particular shape flows better? Or is it just because the openings are bigger?
I'm considering using this material I linked above because the openings are a tad bigger than 1/4 inch, which SEEMS like it should be big enough to flow well. I'm hoping someone has the fluid dynamics know how to estimate how the flow thru this is likely to compare to the flow thru a stock grill with the bar. Don't want to do something that creates a significant reduction in flow compared to stock, but I don't need more either as I'm not boosting power over S stock.
Most of the folks I race with use 1/4 inch chicken wire "grills" to protect our radiators. We know that does create non-trivial obstruction compared to leaving the radiator intake uncovered, but it does not seem to lead to overheating even in desert heat.
Old Nov 22, 2022 | 06:59 AM
cujet's Avatar
At any airspeed we deal with, a round bar (like the components of a robust metal screen) has roughly 10x the drag of a teardrop shaped part. A proper honeycomb design, while not teardrop shaped, may have a thinner cross section along with a long pathway for the air molecules to pass around. Given a proper, open design, will likely flow more air. Whether that matters or not is a guess at this point, as the condenser and radiator create quite a restriction. Simply removing the central bar and badges will increase the available area, so clearly Jag felt the grill opening was ample.
Old Nov 22, 2022 | 12:12 PM
Michael211's Avatar
Exactly what I was hoping to learn. Thanks!
wurldfamuz
Apr 9, 2020 12:36 AM
powerhouse
Nov 14, 2019 07:01 PM
powerhouse
May 5, 2018 04:10 PM
JgaXkr
Aug 6, 2017 11:17 AM
SpacemanSpiff
Apr 7, 2010 07:09 AM
