My Front Plate Solution
Old Jul 2, 2016 | 08:24 PM
  #41
Buckingham's Avatar
Default Illegal europlate
Your front europlate is just as illegal as no plate at all in California. I had one on my M Roadster costom made to match my license as you have. Never got a ticket but still illegal.
Old Jul 2, 2016 | 08:46 PM
  #42
Mulmur's Avatar
Not sure if I mentioned this before; I put a piece of steel, epoxied behind the front black bar, and attached 'earth' magnets to the back of the front plate and it stays in place.
I can remove it easily.
Lawrence
Old Jul 2, 2016 | 09:09 PM
  #43
Unhingd's Avatar
Yes sir, every bit as illegal here in the People's Republic of Maryland as well (and never a ticket either). Running a plate of improper aspect ratio, I suspect, is the least of the traffic sins committed by most members of this forum.
Old Jul 2, 2016 | 10:37 PM
  #44
Foosh's Avatar
Originally Posted by FeralSVR
I've looked and read a lot about the Sto-N-Show plate holder and something about it didn't seem "quite right" from my perspective:
In my opinion, some of the more important features that define the front end of the F-Type are the oval grille surround and the linear front splitter. One of the least is the black bumper bar in the middle of the black grille.
So, to me the license plate mounted on the black bumper bar is a no brainer. It only covers the "unsightly" black bumper bar and a small portion of the black grille behind it while leaving the view of the oval grille surround and the linear front splitter in full view.
I'll readily admit that the Sto-N-Show's primary advantage is that it can be removed revealing the full front end of the F-Type - which is great. However when it is mounted, I find it more intolerable than the factory bracket on the bumper bar which many would like to see removed anyway.
As I said, this is just a different perspective to consider...
The issue is that the only way to mount the factory front license bracket on the bumper bar is to drill holes in it. Most of us would rather not do that.
My plate is always on the car using the Sto-N-Sho, and for me the ability to quickly remove it is not a major attraction, but an undamaged bumper bar is.
Old Jul 2, 2016 | 10:42 PM
  #45
FeralSVR's Avatar
Lawrence
I think Mulmer has come up with a quite eloquent solution that does not require drilling into the black bar...
Old Jul 2, 2016 | 10:47 PM
  #46
Foosh's Avatar
I prefer the Sto-N-Sho location. To each his own . . .
Old Jul 2, 2016 | 11:15 PM
  #47
FeralSVR's Avatar
Agreed!
Old Jul 3, 2016 | 06:49 AM
  #48
Kitesurfer's Avatar
I installed the sho-n-stow but have yet to add the plate since I am in the final days of using my temp plate on the back.
Yesterday we were walking across a large empty parking lot toward the Jag and my wife asked what that ungodly thing was on the front end, referring only to the mounting block.
It's more or less unobtrusive with the exception of the silver mounting bolt and pull pin. Why on earth didn't they color these black?
I think I need to hit both with a few sprays of flat black paint.
Old Jul 3, 2016 | 07:18 AM
  #49
Unhingd's Avatar
When we first got launched with Sho-N-Sto, BierNut was kind enough to buy a 50 pack of these black rings and mail them out to many of us:
https://www.amazon.com/Amanaote-Meta...iglink21907-20
Maybe he has some left. Otherwise someone could invest the $8 and pass them around to the folks recently buying the bracket.
The bolt can be touched up with black appliance paint.
Old Jul 3, 2016 | 07:38 AM
  #50
Kitesurfer's Avatar
Ahhh...thx.
Old Jul 3, 2016 | 10:20 AM
  #51
buickfunnycar.com's Avatar
The beauty of the Sho N Sto plate holder is the angle of the plate once mounted...that slight angle makes it an attractive solution...something you can't say just bolting it up flat against the bumper bar, no matter how you spin it.
Old Jul 5, 2016 | 06:35 PM
  #52
WayneB's Avatar
Default I made a slight Modification to my STO & SHO mounting bracket
I made a slight Modification to my STO & SHO mounting bracket. I replaced the bolt that came with the mount, with a SS flat head screw and counter sank the hole. Don't try this with a hand drill, use a milling machine or the countersink will chatter and walk all over the place because of the 2 small holes beside the main mounting hole. I also used Beirnut's (Thank You) black pull ring. Now the mount is almost impossible to see unless you crawl right under the car. I also used a little Blue Lok Tite under the flat head so it won't vibrate loose.
Old Jul 5, 2016 | 06:41 PM
  #53
themeatbaron's Avatar
I have ordered one for my SVR. Does the plate itself sit low, it looks it to me, but haven't put it on yet, no SVR for about another month and I have Ontario plates as well.
Old Jul 5, 2016 | 06:47 PM
  #54
WayneB's Avatar
Yes it does sit pretty low. If you go back to the original STO & SHO thread, there are lots of photos of it.
https://www.jaguarforums.com/forum/f...racket-144955/
Old Jul 5, 2016 | 07:19 PM
  #55
Unhingd's Avatar
Ahhh...thx.
Biernut mailed me a couple extra black rings which I just ran across today. If you want me to mail you one, just PM me with your address.
Old Jul 6, 2016 | 10:03 AM
  #56
Originally Posted by themeatbaron
I have ordered one for my SVR. Does the plate itself sit low, it looks it to me, but haven't put it on yet, no SVR for about another month and I have Ontario plates as well...
The only way the plate would hit is if you crashed your car, it's far from the lowest point...
Old Jul 6, 2016 | 10:07 AM
  #57
Thanks for the info, i'm not planning on doing that. lol
Old Jul 6, 2016 | 11:05 AM
  #58
Unhingd's Avatar
Also, it protects the front of the car against direct contact with bumper blocks or curbs. It has saved my splitter twice. A little black touch-up paint and the plate frame is good to go for the next collision.
Old Jul 6, 2016 | 11:09 AM
  #59
Unhingd , thanks that is a good point.
DpezXK8
Aug 27, 2025 08:55 AM
H20boy
Dec 24, 2024 03:23 PM
bamforp
Aug 14, 2024 05:36 PM
PMKimpton
Aug 3, 2019 08:22 PM
user 652867429824
Oct 28, 2015 10:18 AM
