Name this sound
Old Sep 11, 2018 | 07:16 PM
Ron Gillespie's Avatar
Default Name this sound
Okay team. I've got an odd noise coming from the backend of my 14 V6 S. Unable to get my phone to record, so I'm throwing out a description in the hopes it's happened to someone here.
The sound comes and goes - both during deceleration and acceleration. Seems to go away if I touch my brakes or put the peddle down hard. The sound reminds me of a modern diesel engine - has that whine to it. Mostly appears at low revs (although maybe just downed out by loud engine at high revs). Like coming into town and you start to slow down, there it is. Doesn't matter if exhaust is on obnoxious mode or regular.
Any suggestions would be welcome. I cannot visually see anything off or loose.
Old Sep 11, 2018 | 07:17 PM
Cambo's Avatar
Vacuum pump for the active exhaust?
Old Sep 11, 2018 | 09:35 PM
Thanks Cambo for the idea. A google search makes it sound like this might be it. I’m not a mechanic....but from what I read, it’s not an urgent fix - nothing is broken, just a vibration apparently? Any additional thoughts on the urgency? Thanks!
Old Sep 12, 2018 | 08:27 AM
WJV's Avatar
WJV
Try pulling fuse F43 in the passenger floor and let us know if that resolves the issue.
Old Sep 12, 2018 | 09:32 AM
DJS's Avatar
DJS
+1 to all. My active exhaust vacuum pump sounds like a buzzing heat shield. It toggles on/off at around idle speeds. Wonder if you can read this document - posted it recently, and was told it wasn't readable...
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
There was a TSB (or something like that) that removed the vacuum pump, and ran a vacuum line back from the engine. Wish I had done this under warranty. I don't seem to have that document.
Old Sep 12, 2018 | 08:54 PM
TSB for noisy vacuum pump. Looks like it’s about an hours labour and a few cable ties and piping. Looks to be a fairly inexpensive fix, which is always nice.
https://jlr.oemdtc.com/74/active-exh...-jaguar-f-type
will try pulling the fuse first though, in case it’s something else.
Old Sep 13, 2018 | 08:56 AM
DJS's Avatar
DJS
Thanks for that - just copied the PDF to my Dropbox collection.
Old Sep 15, 2018 | 10:51 AM
can someone verify....manual says F43 should be red and 10A fuse....but in mine, in the F43 slot, it has a blue, 15A fuse. Was this updated at some point? Thanks.
Old Sep 15, 2018 | 04:11 PM
DJS's Avatar
DJS
Mine too has a blue 15A fuse (which is currently sitting in my glovebox.)
Old Sep 18, 2018 | 09:42 AM
WJV's Avatar
WJV
Same here. Blue and also in my glovebox
Fairlane500
Oct 2, 2025 03:58 PM
rajiga
Jul 28, 2013 09:13 AM
pdog2000
May 4, 2011 07:18 AM
Jaguarnewbie2011
Sights N Sounds
Mar 1, 2011 09:40 AM
bekahchick
Sep 16, 2009 08:38 PM
