Need help!- ECM module
Old Sep 14, 2022 | 02:42 PM
keithguy100's Avatar
Default Need help!- ECM module
Guys & gals. I have a new to me 2016 F-Type- S that was in an accident. The ECM had to be replaced. I have a new to the car ECM and it holds (I think) the odometer reading for the entire car. If I change it out to the used one, does the "used" ECM mileage show up on the dash as THAT newly installed ECM mileage that was on the donor car? KTG--
Old Sep 14, 2022 | 04:10 PM
kb58's Avatar
Most likely, yes. Write down the odo reading before removing the old one, and if necessary, have a Jag dealer correct its replacement.
Old Sep 15, 2022 | 09:39 AM
Default Jaguar ECM
So, does Jag need to "flash" the car too to make the new (Used unit) ECM to work? (That's about $350)
Old Sep 19, 2022 | 06:17 AM
MoJo88's Avatar
Nope. Swap it over over, you're good.
CaptRick
Aug 29, 2020 08:59 PM
jagspeed
Mar 21, 2011 01:59 AM
Teddy
Feb 4, 2010 04:50 AM
xtype owner
Mar 19, 2009 11:16 AM
