Need Help with Possible Backfire?
Old Mar 4, 2024 | 11:11 AM
BigJay13's Avatar
Default Need Help with Possible Backfire?
2017 Jaguar F-Type SVR (No Modifications have been made)
I was driving aggressively on Saturday doing in excess of 100 mph and noticed something of a misfire when I pushed the car past 120mph quickly. As this was the first time I had felt it, I accelerated a few times rapidly past 120 and every time it seemed to misfire or pause at 120MPH. I switched it into Dynamic mode and accelerated past 120 again to see if the results were the same. You guessed it... they were. As a final act, I slowly accelerated through 120 and there was no misfire!!! Aside from that, there are no other problems with the car.
SO, MY QUESTION IS..... What could be going on? Could my timing be off but only showing at 120 mph? Could I have a bad spark plug/ignition coil? Any ideas would be great before I take it to someone.
Thank you all in advance for your assistance over the last year of ownership.
Old Mar 4, 2024 | 12:11 PM
Carbuff2's Avatar
Not timing. Possibly injector issues? (Sticking, not opening all the way)
QUESTION TO OTHERS: Are there secondary injectors that come into play at high RPMs or loads?
If it were a bad plug/ignition you would probably have a passive background OBD code. I'm sure a shop would look at the OBD codes as a first diagnosis.
Slack85
21
Jul 2, 2023 02:47 AM
Martez78
Jul 3, 2020 11:51 AM
Rex
24
Nov 30, 2018 09:52 AM
Xcat112
Feb 6, 2013 01:02 PM
Karmak
Apr 20, 2010 04:22 AM
