Need help unlocking passenger door !!
Old Dec 22, 2017 | 05:32 PM
woodturner's Avatar
Default Need help unlocking passenger door !!
I have been doing some work inside the cabin of my F today, and was needing to keep the passenger door open for a while. With all the talk about the finicky battery, I got concerned about running the battery down, So I thought I'd try to outsmart the car. I moved the lever at the end of the door into what I assume is the locked door position . The pic demonstrates the position it is in currently. In this position the door will not close and properly engage as the lever prevents full closure. I had thought that I could merely then unlock the door using the key fob or the unlock button in the cabin to get me back where I started. Wrong! I am unable to get that lever to move into the position that allows closing of the door. Hoping someone can help.
Thanks.
Old Dec 22, 2017 | 05:48 PM
SinF's Avatar
Fully unlock the car. Get a screwdriver or sturdy pencil, put it into hole inside the latch, then move it outwards. The latch looks like hook, and will move out and up.
Old Dec 22, 2017 | 05:57 PM
woodturner's Avatar
I am able to rotate it some towards a more locked position but not the other direction. Ugh!
would you mind elaborating on exactly where I place the forces?
Old Dec 22, 2017 | 06:28 PM
woodturner's Avatar
Not sure exactly what I did but the door now closes. Whew! Thanks for your help!
Old Dec 22, 2017 | 06:43 PM
15FTypeR's Avatar
When you do that, pulling the door handle (the one on the inside of door) un-does it.
Old Dec 22, 2017 | 07:45 PM
woodturner's Avatar
Had I only known!
Abby's Guy
Nov 14, 2015 02:54 PM
ukwilkie
Oct 28, 2015 06:31 AM
Jakob
Mar 21, 2012 01:42 PM
iownme
Jun 25, 2011 02:26 AM
VitoJaguar
Jun 14, 2010 05:25 PM
