Need an independent Jag Shop in Raleigh, NC
Old Sep 11, 2022 | 09:40 AM
OldGuy1's Avatar
Default Need an independent Jag Shop in Raleigh, NC
I am trying this here since I have had no response on the XE forum. I am having difficulty getting my local dealer to do services that are not EXPLICITLY in the Jag procedures such as a supercharger oil change. I am hoping someone here has had some experience with Independent shops in the area and can share their experiences.
I truly do not understand Jag service not catering to their customers. The result is they will loose service revenue (and they need it) and I will be looking at the new Jags much less often. So on my next buy decision...
Thanks in advance.
Old Sep 11, 2022 | 09:13 PM
uncheel's Avatar
Interesting. I assume you mean Leith. I've used them to do a couple of "non-standard" items on my F-Type and didn't have an issue. The only time I had any issue was on installing my Porterfield brake pads - they did want to do any pad work without rotors. It's not an uncommon position for service departments to take, so I wasn't surprised. I just took it somewhere else. (If it makes a difference, I use the Cary location and not North Raleigh.)
I haven't had much luck finding a shop in the triangle that will work on the newer models. Largely that's because the equipment investment required for anything complicated, and the fact that, with a 5-year warranty/maintenance period, there isn't much demand. I've checked with Flying Circus in Durham, and an independent in Pittsboro, and got the same story.
Tim McGroodt at Foreign Accents might be a option, since he is factory trained, but he's in Greensboro, so not exactly convenient for you. Cheers.
Old Sep 12, 2022 | 11:25 AM
OldGuy1's Avatar
Thank you, I think Autopark Jaguar in Cary is Leith, I haven't tried the Jag dealership at 4001 Capital Hills Dr. Is that where you go UNCHEEL???
Old Sep 12, 2022 | 12:13 PM
uncheel's Avatar
Both locations are owned by Leith. I use the (closer to CH) Cary location, and hit Costco and La Farm while I'm there.
Old Sep 12, 2022 | 03:21 PM
OldGuy1's Avatar
Hmmm not sure why the change but if there is not an existing Jaguar developed process, they are refusing... Will loose a customer...
Old Sep 13, 2022 | 01:48 PM
winstonsalemncxk's Avatar
It is a hike from you, but Everything Euro in Winston-Salem has a former JLR Dealer Tech working for them and I've been happy with their service.
Old Sep 14, 2022 | 10:50 AM
OldGuy1's Avatar
Might be worth going to Winston-Salem If I batch a number of jobs together like the aluminum cooling pipes, SC service, VAP Pulley etc...
Old Sep 16, 2022 | 11:51 AM
GeaBaldyVx's Avatar
Tobola Automotive over off Wake Forest used to do all the work on my Family's Jag growing up. I don't know if they are still doing work on them or not as I moved from NC 6yrs ago and didn't own a Jag at the time.
Old Sep 20, 2022 | 06:08 AM
MV Rider's Avatar
I have found Mike at Triangle Imports located at 3333 Capital Blvd. He will be working on my 2015 XJL on Monday the 26th of Sep. He will be helping me with a headlight issue. The XJLs are tricky as the front bumper has to come off and he will probably need to take the front wheels off to get to the lights.
Old Sep 20, 2022 | 05:39 PM
OldGuy1's Avatar
Thank you, Let us know how it goes...
Old Dec 12, 2022 | 07:27 PM
not an engineer's Avatar
@MV Rider How did the work turn out? I'm also looking for a shop around Raleigh.
Old Dec 12, 2022 | 08:52 PM
OldGuy1's Avatar
Haven't pulled the trigger yet, Still need to come up with my list of parts I want changed. will be a while before I get to it. What are you needing to have done?
Old Dec 13, 2022 | 08:15 PM
tbd. I'm at my first maintenance interval since purchasing. I mainly want a solid maintenance once over as the car didn't come with maintenance history. So I have questions like if the rear differential fluid has been changed, etc. So I can create a plan for future maintenance.
DaleD
Sep 7, 2024 11:24 AM
OldGuy1
XE ( X760 )
Sep 9, 2022 10:31 AM
Jag Fan 83
US Southwest
Jun 15, 2020 12:13 AM
MEPJag
US Northeast
Aug 13, 2016 10:44 AM
RalphFurley
US Western
89
Mar 22, 2013 01:55 PM
