New & improved 10 inch NAV screen upgrade ?
Old Feb 15, 2025 | 08:37 AM
JagCode3's Avatar
Here's one just released with Android 14 and its own DSP. I will see if it can be purchased yet.
HV3 4+64 UIS8581A(SC9863A)Introduction
Old Feb 16, 2025 | 08:58 AM
graybeardnw's Avatar
I actually purchased that unit from Witson last month via AliExpress and went through the whole installation just to find that the unit was DOA. I ended up returning it and will look for something from a different manufacturer.
Old Feb 16, 2025 | 02:15 PM
JagCode3's Avatar
@graybeardnw that sucks, but good to know. The problem is there are very few Jaguar F-Type specific units. And I have found none that cover years 2019 - present which may have something to do with the canbus harness integration. Or is the 2019 and newer still a Harman unit?
Old Mar 12, 2025 | 02:37 PM
OrangeKitty's Avatar
Originally Posted by Tracy Rominger
I have had this head unit in my car for a few months. I can say it works great and the full band equalizer is a god send. The only issue I have had is that the parking sensors look for an all clear from the head unit before it has botted and it causes a warning. I can get around this by putting the car in accessory mode and let the error show then turning the car off then start as normal. Everything works after that. If anyone else has had this issue I would live to hear from you with tour thoughts
Did you install it yourself? How difficult was it?
This YouTube video shows the process for moving the board from the stock head unit into the new one:
Old Jun 20, 2025 | 06:35 PM
Mindvault101's Avatar
Hey, quick question for you. I have the Bosch system and I see in most videos people have to run a wire from the head unit to the area between the seats in the back. Mine has the storage there so I would have to remove the entire back piece off.
Did you have to do that? Or did you just take the motherboard from the OE and put it in the android and connect everything? Thank you
Originally Posted by Evoex
I can't tell you whether it's old or new but I have this unit or at least the software running on this one. It's snappy, very responsive and has not glitched yet after 2 months of use. I would recommend it.
For the install you basically remove the brains from your OEM head unit and install it in here, then in the software you swap back and forth as needed for climate control (vents, etc) and the backup camera screen.
Wireless Android Auto has worked flawlessly.
Old Jun 20, 2025 | 06:43 PM
Evoex's Avatar
I had the local shop install it. But yes, you will likely have to run the cable from the head unit to behind the armrest after changing out the motherboard.
My '16 Ftype back piece came off easily.
Old Jun 20, 2025 | 06:45 PM
thank you for getting back to me!
yea mine has the storage so the entire back pies r including the roll bars have to come off.
not sure if you you know or not, but what is that cable for? The audio?
Old Jun 20, 2025 | 07:44 PM
  #28
Evoex's Avatar
I would assume audio yeah.
Turko
Aug 19, 2024 10:17 PM
Turko
Aug 22, 2023 05:56 PM
Turko
Feb 18, 2023 12:43 PM
Turko
May 30, 2022 11:15 PM
