Newbe Oil Change Question
Old Mar 25, 2020 | 10:33 AM
Lowpass's Avatar
Default Newbe Oil Change Question
This will be an easy one I think. I haven't used the Mityvac oil change method before. Do you connect directly to the tube in the center of the engine oil fill opening, or do you snake the Mityvac hose down the tube?
Thanks!
Old Mar 25, 2020 | 10:52 AM
lizzardo's Avatar
Use the tube in the center of the oil fill opening.
Old Mar 25, 2020 | 12:54 PM
Carbuff2's Avatar
I think the question is better stated as,
"Do I firmly connect the tube to the outside of the metal one under the oil fill cap?"
YES
"Or do I use a tiny tube pushed into the INSIDE of the metal tube?"
NO
Old Mar 25, 2020 | 02:23 PM
lizzardo's Avatar
D'oh! I misread the original question as "use the tube, or snake a tube down separately."
Old Mar 25, 2020 | 05:38 PM
OzXFR's Avatar
And make sure you have a nice tight seal around the extraction tube otherwise the pump doesn't work properly.
Old Mar 25, 2020 | 08:22 PM
Lowpass's Avatar
Much appreciated! I will try to be more clear next time, but your expectations should remain low!
Ter11
Jan 22, 2022 07:25 AM
Chico Mendoza
Aug 28, 2018 11:34 PM
jeremys
Feb 26, 2018 01:47 PM
Bigg Will
Sep 19, 2016 10:38 PM
2002XK8Orlando
Sep 9, 2010 10:04 AM
