OBDII Port issue
Old Jun 18, 2019 | 09:57 AM
jode's Avatar
Default OBDII Port issue
Does anyone know if there was ever a fix for the OBD2 port issues with the battery draining if anything was plugged in? I read the posts about disconnecting the battery to reset and that fixed my problem but I never plugged my GPS tracker in again for fear of the same issue.
Jo
Old Jun 18, 2019 | 10:13 AM
DJS's Avatar
DJS
Nope, no fix. Not all devices to it - check to see if your hazard indicator on the dash is still on 10-15 minutes after shutting the car off, to see if it'll be an issue.
Old Jun 18, 2019 | 10:23 AM
jode's Avatar
Darn it, ok. I will just have to troubleshoot it. Ill wait until the husband is back in town so he can deal with the battery reset thing. Thank you for your reply
Old Jun 18, 2019 | 10:38 AM
Tel's Avatar
Tel
Jo
There is work going on in the background to resolve this issue; I'm in contact with ScanTools (maker of many OBD diagnostic devices your side of the pond) and we are doing some work looking at the finer technical aspects of why this is happening.
Once I have run some more tests with Y-Leads and other adaptors, hopefully, fingers crossed we should be able to 'see' what is missing from so many devices that cause the F-Type to hang and subsequently drain the battery.
Old Jun 18, 2019 | 05:32 PM
Mahjik's Avatar
FWIW, many other cars have the same issue when plugging in things (like Bluetooth adapters) to the OBDII ports. There might be some alternatives out there, but that port isn't developed to be used for anything other than diagnostic purposes.
Old Jun 18, 2019 | 08:52 PM
Unhingd's Avatar
The Maryland Emissions Test causes the fault as well.
Old Jun 19, 2019 | 12:50 AM
jode's Avatar
Here as well. They accessed the OBD port for my state inspection then the car sat for the weekend resulting in a battery drain.
Old Jun 19, 2019 | 07:34 AM
Dogbreath!'s Avatar
Strangely, I have not had the same experience.
Old Jun 19, 2019 | 08:19 AM
Itismejoshy's Avatar
it depends on the device for sure, and i believe if the devise "closes" the connect rather then being yanked from the OBD port is the difference, could be wrong. i have been "closing" or exiting the software i am using and havn't had the issue is since.
Old Jun 19, 2019 | 09:27 AM
Unhingd's Avatar
My experience was at a self serve kiosk. If you had yours done by an inspector, their equipment might be different.
Old Jun 19, 2019 | 10:01 AM
F-Toype's Avatar
Has happened on mine from a state inspection (NH) done at a local indy, as well. It also just happened after a visit to the dealer.
Old Jun 19, 2019 | 01:27 PM
Dogbreath!'s Avatar
Mine was with an inspector. To me it's worth the extra $4.00 to have somebody else do it - I'm lazy.
Old Jun 19, 2019 | 02:24 PM
Lani Kai's Avatar
Funny, if I had the choice I'd pay $4 to not have someone touch my car.
The NY test is done by an inspector and causes the battery drain to issue. I've never had it happen to any other make of car I've had, nor have I heard it happening to those around me.
Old Jun 19, 2019 | 05:45 PM
Unhingd's Avatar
I like crawling around under the dash.
Old Jun 22, 2019 | 01:37 AM
O'Dell's Avatar
It happened to me with a Georgia inspection, too. The dealer replaced the battery under warranty. My question is 'is this going to be an annual thing'?
Old Jun 22, 2019 | 04:48 AM
Unhingd's Avatar
Hopefully, you'll remember what you need to do next time.
Old Jun 23, 2019 | 12:14 PM
jaguny's Avatar
Mine in New York as well, whatever the indie shop does for the inspection (which access the OBDII port).
Old Jun 23, 2019 | 04:36 PM
Terrance39's Avatar
Never had the issue, I keep my bluetooth reader plugged in at all times, you just have to disconnect your phone from it before leaving the car.
Old Jun 24, 2019 | 10:18 AM
mbelanger's Avatar
I vaguely remember seeing similar comments, that the program has to have run to conclusion and THEN the device can be removed from the port without issue. Have never confirmed it independently though. But the only time I had the problem rear its ugly head was after the initial State inspection here in Texas...work done at the dealership never resulted in the problem arising.
Old Jun 24, 2019 | 06:29 PM
O'Dell's Avatar
And what might that be?
