oil change
Old Oct 11, 2015 | 06:33 PM
teacoff's Avatar
Default oil change
Appreciating that the "normal" way to drain the engine oil on an F-Type is thru suction (suction hose right beside the filler cap), does anyone know if the F-Type also has a traditional drain plug underneath? As I have not yet had a chance to put my F-Type up on a hoist to look. Have checked this site and have also Googled, but do not seem to find the answer to my question.
Old Oct 12, 2015 | 10:47 AM
Unhingd's Avatar
Question Correct Oil
For the V6, all available info points to WSS-M2C925 or STJLR.51.5122 specs. The only oil I can find meeting those specs is the Castrol Edge Professional OE 0-20W that appears only to be available in Europe. My local dealer uses Castrol Edge Professional 0-20W (no OE) which neither claims nor denies meeting those specs. It could be that the OE stands for "original equipment", is the exact same oil, and was established for market differentiation (confusion) to allow dealers to sell something at a higher price (which they are doing with the non-OE at $13.35/liter anyway). Anybody have any comment or confirmation of suitability or similar application by other dealers?
Old Oct 12, 2015 | 11:21 AM
strippersteel's Avatar
I'm interested in responses to this as well. Reason being i'm not real close to any Jaguar dealer and would prefer to buy the oil myself and have my mechanic do the oil change if he's able to.
Old Oct 12, 2015 | 11:59 AM
Mikey's Avatar
Wow- talk about thread hijack!
The OP was asking about the presence of a drain plug.
Old Oct 12, 2015 | 12:11 PM
Unhingd's Avatar
What oil to use after you find a drain plug seems to be fairly relevant.
Anyway, went to the dealer to get an answer.
The Castrol edge professional 0w-20 (no trailing letters) specifically meets the Jag specs as stated on the bottle.
Old Oct 12, 2015 | 12:24 PM
Foosh's Avatar
Wow . . . poor guy just wants to know whether there's drain plug or not, and he gets a dissertation on oil specs.
I believe the answer is that there is no drain plug on the oil pan. However, you can buy an oil extraction (suction) device very cheaply at almost any auto supply store or on-line.
Old Oct 12, 2015 | 01:17 PM
Maybe I should have been more clear on my response, I to am interested if there's a drain plug or not. I'm not for sure in my mechanic is equip to vacuum out the oil but if our cars have a drain plug and I could obtain the right oil then I know my mechanic could change the oil. Defiantly not trying to hijack the thread so my apologies if it came across that way.
Old Oct 12, 2015 | 01:26 PM
Foosh's Avatar
You weren't the hijacker. See post above yours:
There is NO DRAIN PLUG
Old Oct 12, 2015 | 01:47 PM
Unhingd's Avatar
This is not on you. I take full blame. I figured that a discussion of motor oil in a thread titled Oil Change would be appropriate. (and I'm sticking to that story).
Old Oct 12, 2015 | 02:24 PM
Mikey's Avatar
I changed from canola oil to EVOO as part of today's Thanksgiving dinner preparations. Damn turkey has it's own drain plug. No vacuum required.
Old Oct 12, 2015 | 03:39 PM
Tel's Avatar
Tel
Default Sump plug
Not sure if you have a V8 or V6?
If it's a V8 lump, then it sure does....
Old Oct 12, 2015 | 05:49 PM
teacoff's Avatar
Thanks for all the replies. Sounds like no drain plug, at least on the 6. Will use a turkey baster to suction out oil. Seeing that today is Thanksgiving in Canada...
Old Oct 12, 2015 | 06:42 PM
Foosh's Avatar
Tel,
Thanks for the clarification, but I suspect you'd have remove the large panel covering the bottom of the engine. Thus, it's not conveniently accessible without putting the car on a lift, then removing that panel.
With an easily accessible extractor tube, the preferred method is a no-brainer, while leaving the car on the ground.
Old Oct 12, 2015 | 06:57 PM
WhiteTardis's Avatar
THIS IS INCORRECT. The V6 very much has a drain plug. Its in the same location as the illustration above. JLR also outlines oil change procedures using the siphon/vacuum method or drain method. If you do go with the drain method, it calls for a NEW drain plug and torque for the drain plug is 24nm.
Old Oct 12, 2015 | 07:48 PM
Unhingd's Avatar
Foosh's comment goes for the V6 as well though: A massive plastic pan under the car needs to be dropped to gain access to the drain plug. Well worth the $40-60 needed to buy a good siphon pump for the job to avoid dissecting the underside of the car. On the similar Ford engines, Ford even calls for using the siphon tube to extract the last third of a quart left in the sump after the oil is drained out the plug.
Old Oct 12, 2015 | 09:02 PM
Stohlen's Avatar
This is good information if you want to 100% make sure you maintain your warranty. If you are out of warranty or realize that no dealer is going to be able to tell specifically what kind of oil you put in, its pretty useless. All the big oil brands are going to meet that spec... but jaguar has a deal with Castrol and thus only approves whatever they put in the engine from the factor. This will not make your motor magically healthier...
Old Oct 12, 2015 | 09:22 PM
Unhingd's Avatar
Originally Posted by Stohlen
T All the big oil brands are going to meet that spec...
That may be true, but you need to know exactly which formulation of the many that they each sell. Note on the bottles: different grades meet different specs. And until Jag refers to standard lubrication industry specs (eg API or ASTM), it is difficult to know which meets the specs Jag specs. For example, the Jag specs appear to require extremely high levels of Titanium in the oil additive package.
Old Oct 13, 2015 | 05:34 AM
Tel's Avatar
Tel
Originally Posted by Foosh
Tel,
That is correct; the splash guard underneath has to come off first to gain access to he sump plug.
Sometime down the line (after the warranty expires) I will remove mine, measure up, and cut a 2 ½'' hole out that I can fill with a nitrile bung, to gain access without dropping the guard in future.
Having never used a suction pump, I'm not sure that it can remove the last of the oil sufficiently thus taking away the most contaminated or 'heavy' oil in the bottom of the sump?
Old Oct 13, 2015 | 06:50 AM
Foosh's Avatar
One can't remove the last of the old oil using the drain plug method in most vehicles either. However, leaving behind a little bit of "dirty oil" is another one of those needless worries.
"The cure for pollution is dilution."
Old Nov 27, 2022 | 03:30 PM
SteveHall's Avatar
I have a 2014 V8s, and I usually use an extractor, but want to do it old school this time. I have a new drain plug ready to go but no torque value. I would think the 24 nm quoted for the V6 here would also apply to the v8, but can anyone confirm?
thanks
Steve
