OK I'll ask: how do people work on the front of the engine? remove the bonnet/hood?
Old Sep 1, 2020 | 07:37 PM
mws's Avatar
mws
Default OK I'll ask: how do people work on the front of the engine? remove the bonnet/hood?
Searched around, saw nothing. Maybe I missed something.
Only had the car a week, but...seriously. I did not think about it until now. How do people work on the front of the engine? or do they make bonnet/hood removal a standard procedure?
Old Sep 1, 2020 | 10:46 PM
lizzardo's Avatar
The only work I've done myself on the front of the engine was the lower supercharger pulley, and I did that after removing the plastic panels underneath. I suppose it would depend on the part I was replacing.
Old Sep 2, 2020 | 05:31 AM
Tel's Avatar
Tel
Being 'Vertically challenged' I actually found it easier to sit on the engine and reach down as I'm not tall enough to stretch over and have enough 'reach' to get further than the oil filler cap!
Old Sep 2, 2020 | 06:39 AM
scm's Avatar
scm
I think you mean altitudinally challenged - vertically challenged means you have difficulty standing upright!
Old Sep 2, 2020 | 04:46 PM
Mbourne's Avatar
To be fair, they both could be true but I defer to Tel.
Old Sep 2, 2020 | 05:02 PM
supersportmtl's Avatar
What "work" are you referring to?
Old Sep 3, 2020 | 04:04 AM
Tel's Avatar
Tel
I did check the Urban Dictionary:
someone who is short.
also known as a midget, a dwarf, the little guy, etc.
man: haha look at that smidget!
AnywayI was having problems spelling attittoodinally, so went for the easy option. Both can be true at times ;-)
For me it was...Belt tensioner release. Checking backlash on the SC snout coupler...generally things that are in the centre.
Old Sep 3, 2020 | 04:38 AM
scm's Avatar
scm
But altitude is to do with height, vertical is to do with upright. Urban dictionary is obviously created by illiterates.
Next you'll be saying horizontally challenged means tall (the logical complement to vertical)!
Old Sep 3, 2020 | 08:36 AM
mws's Avatar
mws
well, anything that has to do with the front of the engine... maintenance; water pumps, radiator pulls, temp sensors, cam position sensors, hoses, you name it. Plus, your sig answers one of my questions: "why do they make a lower crank pulley and spin all the accessories faster just so they can also spin the supercharger faster"? I've never seen that before.
Answer: One reason I can think of is because installing a SC pulley is a PITA, because of the bonnet. People do the crank pulley from underneath, which is relatively easy. (I've seen the posts) I know they make upper SC pulleys, as well, but I have a better idea why they make a SC crank pulley.
I used to own and operate a 300zx modification and maintenance shop: MWS Motorsports. You can look it up on YouTube, or as my name "slkttop". That is what got me thinking.
This forum cracks me up... ;-P. For the record, I am 6'4" and this still concerns me. When I go see the dealer to look at my gas filler pipe, I'll look around to see if there's any F-types in there, and also, ask them.
Old Sep 3, 2020 | 06:32 PM
Unhingd's Avatar
A lot can be done with the bonnet in place, but swapping upper SC pulley will go much easier with it removed. Work on lower part of engine requires pan removal as already said. Depending on which of the 5 radiators, both bonnet and nose might require removal. When removing the bonnet, mark bolt positions to make alignment easier when reattaching.
Old Sep 4, 2020 | 03:50 AM
Tel's Avatar
Tel
Correct...If I could stand at 45 degrees, my apparent height would be less than it already is, so Vertically challenged is ambiguous, however sounds better than Shaw 'Tarse!
If one was 'horizontally challenged', one might struggle to slide under ones' car if using a 'guzunder' for example - that's girth!
Therefore the option to change the lower pulley is out of the question - unless one raises the vertical component of the car.
So to my illiterate understanding, it is a perfectly logical complement to me being Vertically challenged, whereupon I can't get to the can of WD40 on the second shelf without the use of a leg up at 45 degrees or stood straight up! :-)
Johnjagxj
Sep 23, 2018 02:46 PM
caferacer
Mar 21, 2017 08:00 PM
8bit
Nov 1, 2013 09:53 AM
Chris Ryan
Jul 24, 2012 01:59 PM
