P 7 Bumper-less Grille Installed
Old Apr 21, 2017 | 12:52 AM
  #121
Meister_Kajo's Avatar
Yes, I have 3 weeks ago the grille ordered and this should arrive early next week. Then I have to make my mind how I let the part mount ...
Old Apr 21, 2017 | 03:03 PM
  #122
FR500GT's Avatar
Haha I look forward to seeing your results. Please post a write up of the install when you're done!
Old Apr 21, 2017 | 04:04 PM
  #123
Unhingd's Avatar
A number of us have the P7 grille and surround sitting in the corner, ready to go in, as soon as we come up with an elegant solution for mounting the 2 front parking sensors that fit in the crossbar. Just gluing the sensors to the P7 honeycomb just doesn't seem like the right solution for a car of this stature.
Old Apr 22, 2017 | 06:43 AM
  #124
DJS's Avatar
DJS
Sounds like you need someone with a 3D printer and some design skills.
Old Apr 22, 2017 | 06:46 AM
  #125
ShaunPA's Avatar
if you end up not using it, i'll buy it. luckily, i don't have the problem to worry about
Old Apr 22, 2017 | 07:10 AM
  #126
Unhingd's Avatar
Volunteers are welcome!
Sounds like another product for the Unhingd Performance Division. Spend a year and a half on R&D to sell all of a dozen units. Just my kinda project.
Old Apr 22, 2017 | 12:32 PM
  #127
FR500GT's Avatar
lol
Do ALL models use the same sensors?
Old Apr 25, 2017 | 08:26 AM
  #128
The grill and the surround arrived today with the post office. The processing is mediocre, but if the part is installed, this is no longer relevant. I will leave the surround still foliate. Does anyone have a photo of the original park sensors and the dimensions of the diameter? I now have to ask a friend who has pure 3D printer whether he could make these two parts to me.
Old Apr 25, 2017 | 10:11 AM
  #129
Unhingd's Avatar
I have two new sensors at home, ready to be installed as soon as someone can come up with a mounting solution. I will get the full dimensions to you later today.
https://www.jaguarlandroverrenoparts...Y2LWdhcw%3D%3D $108
https://www.aliexpress.com/snapshot/...Id=32577782064 $13
Pick your price point.
Old Apr 26, 2017 | 01:55 AM
  #130
Is that the same sensor? This would be faster to order for germans.
PDC Sensor Einparkhilfe Ultraschall für LAND ROVER RANGE ROVER 4 IV LG | eBay
Old Apr 26, 2017 | 02:35 AM
  #131
Unhingd's Avatar
Yes. You will also want a couple of sensor retaining rings: C2Z11732
JAGUAR OEM F-Type Front Bumper Grille Grill-Park Sensor Retainer Ring C2Z11732
Old Apr 26, 2017 | 06:22 AM
  #132
Now assume the two park sensors with the holder rings have
arrived. Then I leave the insert with the 3 D printer
finished with the appropriate hole for the rings of the
Parkensors. After that I leave the original park sensors.
After installation on the grill, I plug the cable to the
new parking sensors. Is there still something to be encoded
here or only the distance calibrated again?
Old Apr 26, 2017 | 08:05 AM
  #133
Unhingd's Avatar
Please excuse the crappy penmanship. It's tough doing it right with a broken finger.
Old Apr 26, 2017 | 08:41 AM
  #134
What color, varnish did you use to paint the cooler?
How did you move the cables of the sensor so that you
can not see them from the outside?
Old Apr 26, 2017 | 08:48 AM
  #135
Unhingd's Avatar
I haven't started this project yet. I think someone further back in the thread describes the routing of the wires.
Old Apr 26, 2017 | 10:53 AM
  #136
jleuz1's Avatar
When I did mine, after removing styrofoam from bar behind grille, the bar was the only thing I had painted in flat black.
2 Instead of mounting sensors with connectors pointing inward, as they do on the original bumper bar, he pointed them outward in order to avoid having wiring exposed behind grille. He glued wires from sensors directly around trapezoids so they can not be seen, and they exit to the side of grille.
3 He then mounted wiring harness to run below grille, (there is a lip below the grille that he fit it into)and then extended sensor wires to go below and around surround. Since sensor wires are not color coded, he colored them with different colored nail polish before he cut them. I thought the sensor wires looked to be about 24 gauge but couldn't find it locally and didn't have time to order it online so I found a couple old power supplys from a radio and an old router which I think is 24 gauge and he cut it up and spliced them in. They work!
Hope this helps.
Old Apr 26, 2017 | 01:17 PM
  #137
FR500GT's Avatar
I just realized that the base model doesn't have the parking sensors in the grill. Looks like it's time to order!
Old Apr 26, 2017 | 07:05 PM
  #138
Mbourne's Avatar
Wow hard to not comment on that photo
[/QUOTE]
Old May 1, 2017 | 06:13 AM
  #139
I have now decided not to mount the grille of Paramount performance.
The quality of the grill is very bad and it was also very badly
processed. I recommend everyone to buy only the original parts of the P7.
Unfortunately you can not order these at the moment. I also do
not like the glue solution, so I stay with the original grille.
Too bad, but I mount no inferior part at a 130,000 € car.
Old May 1, 2017 | 06:15 AM
  #140
I will return the parts Paramount Performance and reverse the purchase.
I hope to find a satisfactory solution in the near future,
which I will then choose.
