P0051 & p0063
Old Nov 9, 2021 | 09:39 PM
Molotovman's Avatar
Default P0051 & p0063
Hey guys new here I just got my v6 16' with 26k miles. Was doing great for a week then I get those codes. I realized they are both connected to fuse 11 under the hood. Checked the fuse and it was blown. I replaced the fuse blew right away again. Would a faulty sensor cause the fuse to blow? Before I take it to a shop any suggestions?
Old Nov 10, 2021 | 06:33 AM
Therock88's Avatar
I would check the O2 wiring on Bank 2, as one code is for the first O2 (located in manifold) and one is for the last O2. If it is blowing fuses, then it would seem you may have a melted wire/O2.
That is where I would start. If you have the ability to log the data, you could monitor Bank 2 O2 sensor voltage and that may clue you in to what is going on. Beyond that, may need to have shop connect SDD/IDS to troubleshoot.
Good luck.
DC
Jaesteban
Feb 10, 2020 09:00 AM
Stuart1960
E type ( XK-E )
Aug 25, 2019 09:49 AM
stevepaa
Jun 11, 2017 03:50 PM
beddowes1
May 12, 2010 05:06 AM
Mar 3, 2007 11:37 AM
