P0480-11 code. Bad fan controller?
Old Apr 21, 2025 | 11:20 AM
Adam Deermann's Avatar
Default P0480-11 code. Bad fan controller?
Hi,
I can’t find the scource for a P0480-11 code, which triggers the fan to be constantly.
I just rebuild the engine and everything was out of the car, including most of the wiring. Since everything was installed (except the bumper/bumperharness) this happened. Must be related to the installation, it didn’t do it before the rebuild.
I looked at the wires and and I can’t find a problem there. Now I think the only option is to buy a new fan. But is there something else to look for?
thx
Adam
Old Apr 21, 2025 | 11:30 AM
NBCat's Avatar
What is available voltage across the battery terminals with the ignition in the OFF position for thirty minutes or longer?
Check pins in connectors to ensure there aren't any bent or not making proper connections. ECM/PCM controls the cooling module earth/ground.
Old Apr 21, 2025 | 12:12 PM
DJS's Avatar
DJS
P. 293 of the Workshop Manual…
https://www.dropbox.com/scl/fi/o6d1x...=pm0em925&dl=0
Old Apr 21, 2025 | 12:31 PM
DJS's Avatar
DJS
This is also in that document, as are schematics…
Old Apr 21, 2025 | 12:51 PM
DJS's Avatar
DJS
The schematic is quite confusing, until you realize there are either two 850W fans (hot markets), or two 500W fans (rest of world)
Thx. So it might be missing a ground or it measures a low voltage.
so a lot of measuring….
Old Apr 21, 2025 | 12:53 PM
DJS's Avatar
DJS
No, a missing ground wouldn’t do it.
Old Apr 21, 2025 | 12:56 PM
the dotted lines are 850W?
Old Apr 21, 2025 | 01:18 PM
DJS's Avatar
DJS
No, the two fans labeled ‘motor-cooling-fan-2’ are 850W, you can see the label on the red VBATT lines. The two labeled ‘motor-cooling-fan-1’ are the 500W ones, presumably what you have. You have one pair or the other.
Old Apr 21, 2025 | 01:22 PM
DJS's Avatar
DJS
What you care about are the blue PWM lines. If these are floating (open) or shorted, your fan stays on all the time.
Old Apr 23, 2025 | 01:51 PM
Found it.
Harness was squeezed by the subframe.
Repaired it and problem solved.
Old Apr 23, 2025 | 08:15 PM
JagCode3's Avatar
@DJS Thanks for the schematic and spot-on diagnosis. You are always incredibly helpful!
Old Apr 23, 2025 | 08:25 PM
DJS's Avatar
DJS
Old Apr 24, 2025 | 08:03 AM
clubairth1's Avatar
Community Influencer
Impressive Internet diagnosing DJS!
badicedog
Nov 29, 2023 10:14 AM
mrmike
Jun 6, 2021 07:02 PM
chromedragon
Nov 1, 2012 06:24 PM
Terry
Apr 29, 2012 08:54 AM
