P2187 due to catch can?
Old Mar 31, 2025 | 03:25 PM
AZP450's Avatar
Default P2187 due to catch can?
I recently installed a catch can on my 2024 P450 and have been getting the P2187 and P2189 faults 'System too lean at idle' for both banks 1 and 2. My install is tight and has no leaks. Has anyone experienced this after installing a catch can?
Old Mar 31, 2025 | 05:41 PM
JagCode3's Avatar
@AZP450 Can you show which hose and where you tapped into? There is a leak somewhere, most likely where you tapped but something may have been jostled during the install.
Here's a nice use of a smoke machine to do what the dealer couldn't (Thanks to Alex Revive on YT):
Old Mar 31, 2025 | 06:17 PM
AZP450's Avatar
Thanks JagCode3, I rechecked everything and you were right, the threaded can itself somehow started to loosen. I removed it and found about 1/4" of oil collected in it after only 1000 miles. I cleared the codes, tightened the can and will see what happens. Based on what has been collected so far I don't think the Jag's oil separators are efficient enough. I certainly want to avoid coking up the intake valves.
Old Mar 31, 2025 | 06:27 PM
Evoex's Avatar
Had my intakes cleaned when i had the plugs, coolant hoses, etc done. Tech said they were a mess at 67,000km.
Old Mar 31, 2025 | 06:44 PM
JagCode3's Avatar
@AZP450 That's good news. I am debating doing this and probably will when I pull my SC off to replace the coolant pipes and clean the valves. What unit did you decide on installing? I always wondered if the right side OEM oil separator did a sufficient job.
@Evoex That is my fear (especially after owning an Audi TFSI with a serious carbon deposit issue) - did you install a catch can? I was also considering an oil separator in lieu of a catch can.
A big thank you and Shout-Out again to @HermanWiegman @Onca Engineering for his great videos and expertise on this forum!
Old Mar 31, 2025 | 06:50 PM
Evoex's Avatar
https://www.youtube.com/watch?v=SrmtwG6APoQ
I have not as of yet. I plan to discuss with my tech in a few weeks when i get new rubber mounted.
Old Jul 9, 2025 | 05:01 PM
energie's Avatar
Can you show how did you install it?
which brand did you use?
thanks
2001 White XJ8
Feb 12, 2020 06:43 PM
Hooshee
Jul 14, 2018 08:53 AM
johnd8008
Feb 10, 2014 06:23 PM
dsetter
Feb 6, 2013 05:49 PM
Double Tap
Aug 11, 2011 10:23 PM
