Parking Brake
Old Mar 13, 2025 | 09:57 PM
Crustacean99's Avatar
Default Parking Brake
Hello, my F TYPE R recently required a trip to the dealer that I thought was bad injectors but what turn out to be just bad gas.
Fearing the worst, I had the car towed to the mechanic and had the tow truck driver use the emergency release as opposed to starting the car.
Now that it’s back in running condition, its displaying a parking brake inoperable message on the dash, is this a by product of using the emergency release?
Old Mar 14, 2025 | 12:11 AM
sov211's Avatar
Well, logically yes, and logically it may be that the brake release unit in the console has not been restored to the normal setting.
Old Mar 14, 2025 | 11:43 AM
How do I go about restoring it to the proper setting?
Old Mar 14, 2025 | 06:51 PM
sov211's Avatar
Well, to begin with, look inside the centre console where the emergency brake release is located (under a black panel at the side of the box). Your owner’s manual has the instructions for using this release; presumably you reverse the procedure to lock it again. I cannot comment further because I have never needed to use the emergency release. Sorry.
Old Mar 14, 2025 | 08:57 PM
The manual doesn’t describe a reset procedure unfortunately
Old Mar 14, 2025 | 10:32 PM
OzXFR's Avatar
Yep, it simply says "Components should be refitted in reverse order".
See attached PDF for the release procedure, sorry if it comes out sideways!
Edit - something screwy going on with my upload, but long story short the attached PDF does contain instructions on how to reset the emergency Park release, my WAG is the OP / tow truck driver / whoever didn't do this.
File Type: pdf
Old Mar 15, 2025 | 07:16 AM
DJS's Avatar
DJS
Looks fine, Oz.
It's worth noting that this procedure was missing from the first model year’s Owner’s Handbook. I have a printout of it that I added to my manual.
AnnetteF
General Tech Help
Oct 31, 2024 02:43 AM
blackphoto5
Aug 6, 2020 04:39 AM
pelle
Jan 25, 2018 09:16 AM
Adam Lueb
Jul 19, 2016 12:55 PM
millenia man
Jan 29, 2011 05:06 PM
