PB brakes
Old Jun 25, 2024 | 06:22 PM
Doc Oc's Avatar
Default PB brakes
Don't see much about them here but I pulled the trigger last month and just got around to installing them today. Easy job, plug n play....went from base 355 to an 8 pot 365 mm rotor. Best part is the weight savings. Didn't realize just how massive the oe rotors and calipers are! OE caliper weight is 20.5 lbs. PB caliper is 10 lbs. OE rotors weigh 21 lbs. PB rotors weigh 14. So I gained braking performance and lost 17 lbs per corner of unsprung weight! Can't wait to see how they handle the mountains!
Old Jun 25, 2024 | 07:44 PM
Moniker's Avatar
Looks great, looking forward to hearing how the brakes perform
Old Jun 26, 2024 | 06:10 AM
Atipical's Avatar
Those look fabulous. How much was the set?
Old Jun 26, 2024 | 11:43 AM
matt8686's Avatar
also curious about cost.
did you do front and rear?
Old Jun 26, 2024 | 11:51 AM
Doc Oc's Avatar
Thanks all. Cost was around $2100 for the front set. Rotors, pads, calipers and braided lines. The rears are actually more because of the built in parking brake so I didn't bother with them.
flescher
General Tech Help
Dec 12, 2022 03:37 PM
tmich
Dec 13, 2020 10:25 PM
Dave Redline
Feb 13, 2020 05:22 AM
mshedden
Apr 8, 2018 05:43 PM
quaker13
Aug 13, 2011 08:05 PM
