pic of motor shows up
Old Apr 30, 2022 | 01:06 PM
santacruz11's Avatar
Default pic of motor shows up
started the j car this am and that little pic of the motor shows up . checked information , oil fine sez ok for all else . car runs fine . thinking it is a sensor any ideas, thanks in advance
Old Apr 30, 2022 | 01:36 PM
texas jag's Avatar
The little picture of the motor is the “check engine” light. Reference page 37 of your manual. Need to get codes read out. If light begins to flash, it’s urgent.
Old Apr 30, 2022 | 01:58 PM
kb58's Avatar
Buy or rent a decent OBD2 reader. I just bought a reader because it only takes 1-2 trips to a shop to pay for one. If you never work on your cars... oh well, take it to a shop.
Old Apr 30, 2022 | 04:29 PM
Valerie Stabenow's Avatar
Default CEL
The CEL, Check Engine Light may illuminate if your gas cap isn't snug and you may want to check your coolant container cap for the required 3 clicks to make sure it's on correctly. I don't remember if the coolant cap issue will turn on the CEL, but do check this anyway.
Also, if you had a drastic temperature change,, like warm to cold, this may make the CEL come on. It did that on the MY2017 that I have. Be careful using the OBD readers. Some of them create battery drain issues if the session is not closed out properly... there are whole threads devoted to this.
Old Apr 30, 2022 | 06:42 PM
thanks to all , cleared the check eng lite took the j car for 50 mile ride (all speeds) and not ck lite
Old May 7, 2022 | 03:15 PM
had 80 corvette 4 speed kept it for 4 years and traded it stright across for a 63 corvette split window 340 hp solid lifter5 car , best trade i have ever made
Spud Maat
Nov 8, 2021 06:52 AM
Montalbano
Jun 17, 2021 12:44 AM
04xtype04
Feb 18, 2014 10:02 AM
