Please Help With Codes
Old Jul 31, 2024 | 10:26 AM
moonlitsouls's Avatar
Default Please Help With Codes
Hello jaguar family, we have a check engine light and the roof won’t retract
Any help would be greatly appreciated
Old Jul 31, 2024 | 10:47 AM
NBCat's Avatar
Before attempting any further diagnosis, check the available battery voltage.
With the ignition in the OFF position for at least 30 minutes, use a voltmeter across the battery terminals to read the available voltage. The voltmeter should display a minimum of 12.6 volts. If it shows less than 12.6 volts, charge the battery for five hours at 2 to 5 amps and retest. If the voltage is still less than 12.6 volts, the battery is suspect and should be replaced before going any further or replacing parts.
Old Jul 31, 2024 | 11:01 AM
hello friend, the mechanic claims he already tested the battery thoroughly, and it’s a new battery
Old Jul 31, 2024 | 11:25 AM
NBCat's Avatar
If the Technician tested the battery, did he or she provide you with a print out of the readings? If so, post them here.
Just because a battery is 'new' doesn't mean it's fully charged.
Old Aug 5, 2024 | 10:39 PM
diablo2112's Avatar
+1 make triple-sure your battery is charged. These cars throw all sorts of codes on partially-charged batteries.
Old Aug 6, 2024 | 10:02 PM
WhiteTardis's Avatar
These are all very random codes. As other mentioned, I would check the battery condition. My theory is that a low voltage situation is causing incorrect readings from the ABS module (which, btw is tied to the module that controls the softtop) as a result, not closing. Those incorrect reading are then freaking out the ECM. I would definitely start with a healthy battery, clear the codes, and see if it comes back.
NYCJAG2006
Nov 23, 2023 12:24 PM
NYCJAG2006
Sep 11, 2023 04:09 PM
NYCJAG2006
May 16, 2022 04:34 PM
Oxidizer2k
Dec 31, 2020 02:56 AM
Rip Reed
Dec 26, 2011 07:46 AM
