Position of door rubber seal?
Old Dec 19, 2021 | 04:04 PM
MajorTom's Avatar
Default Position of door rubber seal?
How is the rubber seal circled in red supposed to sit - under or over the plastic trim piece marked with the X?
The pic is from my driver's door and most of the seal is underneath the plastic part, but partially it's over it. It feels like it should all be on top of the plastic part, just like the other seal right above the circled area. Any ideas how this is supposed to sit?
Old Dec 19, 2021 | 04:35 PM
Mahjik's Avatar
Looks normal.
Old Dec 19, 2021 | 04:54 PM
MajorTom's Avatar
Ok, so all of that seal should definitely be under the plastic door trim?
It's really easy to flick it over to the outside and when I tried that with a piece of the seal on the lower part of the door it let out some water. This was right after a car wash which is why there was some water inside but I want to make sure that this is positioned correctly so that water doesn't get trapped somewhere in the door.
Old Dec 19, 2021 | 05:16 PM
Mahjik's Avatar
Your photo looks normal as is...
Old Dec 20, 2021 | 11:03 AM
MajorTom's Avatar
Having that seal under the loose plastic trim just didn't look or feel right after all. Did some online research and on every single car I've seen the seal is on the outside, so I pulled it out. This is the way it's supposed to look.
Looks like the door cards were off at some point and the seals weren't positioned correctly afterwards. Or maybe it came like that out of the factory. It wouldn't be the first time I had to adjust some trim and seals on a Jag. :P
Old Dec 20, 2021 | 01:14 PM
Carbuff2's Avatar
^^ I finally remembered to look at ours, and they are positioned as above.
(Wifey said WHAT ARE YOU LOOKING AT? HANDS OFF MY CAR!)
SamtheSham
Mar 26, 2020 05:45 PM
hlgeorge
16
Jun 29, 2019 02:11 PM
Gerard Radimaker
Mar 14, 2019 05:58 PM
jackconcord
Apr 3, 2015 04:22 PM
GrafShutka
Aug 15, 2010 12:56 PM
