Possible purchase - when is a service history too lengthy??
Old Nov 1, 2025 | 04:24 PM
FTypeInTheSun's Avatar
Default Possible purchase - when is a service history too lengthy??
I'm seriously looking at a 2016 S Convertible with 47,795 miles on it, the cost is $31k. The car has everything I'm looking for in terms of options and colour combination. When I pulled the CarFax I was a bit suprised by the amount of service history attached to the car. I'm not sure if to be thrilled about it, or if it's a red flag...
The history is very lengthy, I'm just wondering if some of the work that has been done could indicate a problem car? Or if I should be happy that so many things have already been done?
I'd love opinions if anyone has them, this forum has already been invaluable and I really appreciate any help! Thanks in advance!
SERVICE HISTORY
  • Zia autohaus
    9/19/2025
    47,463 mi
    • Vehicle serviced
    • Battery replaced
    • Oxygen sensor replaced
  • AutoGlassNow
    06/09/2025
    46,132 mi
    • Vehicle serviced
    • Glass repaired
  • Zia autohaus
    04/25/2025
    45,525 mi
    • Vehicle serviced
  • Zia autohaus
    04/15/2025
    45,091 mi
    • Vehicle serviced
    • Maintenance inspection completed
    • Antifreeze/coolant flushed/changed
    • Coolant flange replaced
    • Cooling system checked
    • Drain plug gasket replaced
    • Oil and filter changed
    • Thermostat replaced
    • Tire condition and pressure checked
    • Water pump gasket replaced
    • Water pump replaced
  • Land Rover Albuquerque
    9/17/2024
    39,354 mi
    • Vehicle serviced
  • Howard Orloff Imports, Inc.
    10/21/2022
    33,446 mi
    • Vehicle serviced
  • Jaguar Land Rover Northfield
    07/25/2022
    32,865 mi
    • Vehicle serviced
    • Computer(s) checked
    05/31/2022
    32,385 mi
    • Vehicle serviced
    • Battery/charging system checked
    • Body water leak checked
    05/05/2022
    32,346 mi
    • Vehicle serviced
    • Noise checked
    11/11/2021
    32,007 mi
    • Vehicle serviced
    11/23/2020
    27,130 mi
    • Vehicle serviced
    • Brakes checked
    11/11/2020
    26,847 mi
    • Vehicle serviced
    10/23/2020
    26,845 mi
    • Vehicle serviced
    • Brakes checked
    • Turbocharger replaced/repaired
    08/17/2020
    26,025 mi
    • Vehicle serviced
    06/04/2020
    23,475 mi
    • Vehicle serviced
    01/10/2020
    20,205 mi
    • Vehicle serviced
    • Anti-theft/keyless remote battery replaced
    • Four tires balanced
    • Four tires mounted
    • Four wheel alignment performed
    • Wiper(s) replaced
  • Imperial Motors Jaguar of Lake Bluff
    05/09/2019
    14,005 mi
    • Vehicle serviced
    • Recommended maintenance performed
    • Brake fluid flushed/changed
    • Heated oxygen sensor replaced
  • Jaguar Land Rover Schaumburg
    07/17/2017
    5,827 mi
    • Vehicle serviced
    • One tire balanced
    • One tire mounted
    • Tire(s) replaced
    • Vehicle washed/detailed
    10/05/2016
    3,038 mi
    • Vehicle serviced​​​​​​​
Old Nov 1, 2025 | 04:57 PM
JagCode3's Avatar
Appears to be a well-maintained F-Type and low mileage for a 2016. No red flags to my eye.
Old Nov 1, 2025 | 05:27 PM
Thanks for the opinion! Is the following service a clue that the dreaded coolant pipe problem these cars have might have been resolved already?
04/15/202545,091 miVehicle servicedMaintenance inspection completedAntifreeze/coolant flushed/changedCoolant flange replacedCooling system checkedDrain plug gasket replacedOil and filter changedThermostat replacedTire condition and pressure checkedWater pump gasket replacedWater pump replaced
Old Nov 1, 2025 | 06:15 PM
CarlB's Avatar
Old Nov 1, 2025 | 06:16 PM
Originally Posted by CarlB
Not good? 😬
Old Nov 1, 2025 | 06:22 PM
CarlB's Avatar
Originally Posted by FTypeInTheSun
Not good? 😬
I was assuming 2016 didn't have the turbo I4 available.
Old Nov 1, 2025 | 06:41 PM
lizzardo's Avatar
That's correct. No turbocharger. Even if it is supposed to say supercharger, that's awfully low mileage.
Old Nov 1, 2025 | 06:50 PM
OzXFR's Avatar
My WAG is they are talking about the SC coupler and/or snout.
Old Nov 1, 2025 | 07:59 PM
Valerie Stabenow's Avatar
Default Coolant pipes
Yes, water pump had to be changed when replacing the coolant pipes, as documented on the warranty invoice for my MY2017, built late 2016. As for the "Turbocharger" probably meant supercharger. This an early car, so probably some early production issues. On my 2017, a manual trans car, there were stories of owners not even getting the car home and the clutch had failed. JLR was on the 4th gen clutch by the time I bought mine. 24,000 miles at that time (2020) and 43,000 now with no clutch issues. Car was missing fender bolts for the RHS headlight assembly and the nighttime ambient blue lighting in the doors and grab handle was not enabled prior to my ownership.
Make sure the center went unit raises and lowers quietly and spend some more time on this forum to learn as much as you can.
Best wishes!
Old Nov 1, 2025 | 10:47 PM
Thunder Dump's Avatar
This one would concern me. Clogged roof drains can cause rainwater to end up in the trunk where all the electrical components are. I'd definitely want more info on what the complaint and resolution was.
Old Nov 2, 2025 | 07:58 AM
JagCode3's Avatar
I am looking at this through the perspective of a detective. If you look at the dates you can infer that if there was a major problem it would have reappeared. Keep in mind this is a 10-year old car that spent most of its life in Chicago (rain and snow) then moved to New Mexico and not owned by a DIY'er. If the exterior and interior are in excellent condition then it was garaged and well-cared for based on the service history.
  • The coolant system was serviced earlier this year, most probably for a leak. If there was a catastrophic engine overheat that would be the end of the engine.
  • The body water check was done in 2022 and nothing since. A check of the floor of the trunk would reveal corrosion if this were recurring. Pulling up the carpets in the foot wells would reveal prior water intrusion. It looks like the issue was resolved. The battery survived 9 years so that's also a good sign.
  • The turbocharger (obviously SC) was done in 2020, probably for coupler noise.
As a potential new owner of a 10 year old F-Type convertible you:
  • will need to always be on the lookout for a coolant pipe leak at any given time while driving (use Torque Pro or another OBD2 app to monitor you coolant temp). Many on the Forum have replaced the coolant pipes proactively for this reason.
  • will need to watch out for water intrusion and monitor the convertible drains if you drive it or keep it parked outside in the rain.
  • will probably have a SC clunk after turning the engine off. Most of us just live with it as it is not damaging the engine.
Send us the link for the car so we can take a look...
Old Nov 2, 2025 | 08:07 AM
bfrank1972's Avatar
Just a couple quick comments:
1) overheating and engine doesn't necessarily mean the engine is toast. They can "survive" for a while but likely will have weakened head gaskets or a small breach that hasn't yet made a big impact. Gotta look closely at those things. That said, just because it had the pipes changed doesn't mean there was an event. If all the work was done at one dealer or shop, maybe they could give you some history.
2) look closely at oil change intervals, long change intervals can cause problems for these motors as well
3) an sc clunk may not be a problem, but could be a problem, and if not investigated/addressed certainly can lead to other issues
get the car inspected by a shop that knows these cars, best insurance IMHO
Old Nov 2, 2025 | 08:31 AM
JagCode3's Avatar
Good point about the overheating - just call Autohaus Zia to get the repair details.
There are a lot of F-Types for sale. Getting the right color combo limits you quite a bit, as everyone's preference differs..."Art is subjective"...
https://autocac.com/product-details....645400014fb075
Old Nov 2, 2025 | 08:39 AM
bfrank1972's Avatar
Lol, dear God please let that be a vinyl wrap
Old Nov 2, 2025 | 10:18 AM
The car is here if you'd like to take a look!
I've put a hold on the car for now while I do a bit more digging, all of the information people provided here is super helpful, I really appreciate it!
Old Nov 2, 2025 | 10:30 AM
JagCode3's Avatar
The color combo is great, really like that grey. Very easy to care for (unlike black or dark blue which show swirls and pollen). Go for it...
Old Nov 2, 2025 | 02:20 PM
6MTFType's Avatar
Did the Carfax show damage? The photos and some of the descriptions indicate paintwork and chipping. Paintwork (as best I can tell based on limited ability to zoom) does not appear to be great. Can’t tell what brand or age the tires are. As others have said - have a reputable Jaguar experienced shop inspect. Unless flawless, then pass.
Old Nov 2, 2025 | 03:42 PM
JagCode3's Avatar
"Unless flawless, then pass." How is this decree even possible when buying a used car that is not a rare collectible? Based on the service history and exterior, the car is not flawless.
The "flaws" are why this forum exists.
Use the 7 day grace period to decide if you want to keep the car. You can reject it at time of delivery if it does not meet your expectations or if there are missing features. Take pictures of the body and wheels/tires with the delivery truck in the background. The tires and brake pad depth should be checked with your initial inspection. If worn they should cover it as it's a safety issue. If they refuse during the 7-day period then send it back. You can even have the work done at a JLR dealer and they will pay for it, but needs to be initiated during the first 7 days. Or keep looking for a flawless old F-Type...
https://www.jaguarforums.com/forum/f...3/#post2879827
Old Nov 2, 2025 | 04:23 PM
6MTFType's Avatar
Best of luck with your purchase!
kennedyhow
Jul 21, 2022 10:12 AM
NavyBlue
Jan 3, 2022 04:26 PM
detheridge02
Nov 4, 2019 03:10 AM
gavinw35
May 19, 2012 06:37 AM
rlwpromo
Apr 30, 2010 02:52 PM
