Rain Mode
Old Nov 24, 2015 | 01:16 PM
Buckingham's Avatar
Default Rain Mode
It's actually raining hard in the SF Bay Area. I could check out the rain mode, but do I want to get Buckingham muddy? What a dilemma.
Old Nov 24, 2015 | 02:26 PM
Foosh's Avatar
Just test the rain mode when it's dry and sunny outside. You'll immediately see why it's suited for rain and snow. :-)
Old Nov 24, 2015 | 03:26 PM
Neek's Avatar
Just imagine a slower F-type with less throttle response.
Old Nov 25, 2015 | 04:40 AM
AnD3rew's Avatar
Mine is a daily driver so no choice but to take it out into the rain. After a few butt clenching experiences in the wet with cold P Zeros I use it most of the time when it is wet.
Old Nov 25, 2015 | 03:46 PM
Nati's Avatar
obviously the wet mode is designed to help with breaking traction while accelerating, but are people finding the P-Zeros to be problematic with cornering or braking when it's raining? They have a pretty good wet rating on tire rack.
Old Nov 25, 2015 | 04:20 PM
kingkong79's Avatar
Never tested the P-Zero with higher speed cornering and braking while raining. I know the P-Zero can break loose from a stop when raining. I always use rain mode when road is wet. Don't want to test my driving skills. Rain mode makes the F-Type feel like Toyota Camry.
Old Nov 25, 2015 | 05:12 PM
Nati's Avatar
Now I'm curious because a lot of people call it rain mode. In my market the button has snow flakes on it, and it's referred to as winter mode. Does this vary regionally? Is it the same thing?
Old Nov 25, 2015 | 06:53 PM
TXJagR's Avatar
It's the same thing. Rain / Snow mode.
Old Nov 25, 2015 | 09:51 PM
Mbourne's Avatar
I don't trust the pzeros in the rain so I put it into rain mode as soon as the road is visibly wet. It's piece of mind.
Old Nov 26, 2015 | 06:26 AM
Unhingd's Avatar
Maximum wet traction with the p-zeros might be good, but when they let loose, it's like falling off a cliff. The PSSs will give you plenty of notice they are on the edge and will give you the opportunity to reign things back in again.
Old Nov 27, 2015 | 05:17 AM
AnD3rew's Avatar
Yep in this car the PZeros let loose fast and unpredictably. I have had several hairy experiences including having the back overtake the front on a suburban road with only moderate acceleration in the wet.
Old Dec 15, 2015 | 04:49 PM
Uncle Fishbits's Avatar
I finally used the Rain / Snow mode. It's fascinating. It turns the car into a Hyundai. I joke I joke... but it's obviously drastic.
What sort of weather are you actually using this? Heavy downpour, or even when the roads are wet? What speeds are you driving on wet roads in these p-zeros?
Old Dec 15, 2015 | 07:08 PM
Unhingd's Avatar
Might be useful on snow and ice, but not much else. When the roads are plenty wet I leave in normal mode, but in fair weather use TracDSC when I'm in the twisties. I can't speak for the p-zeros, but at legal (or slightly more) speeds,no need to throttle back on the PSSs in the rain except in tight turns.
Old Dec 15, 2015 | 07:37 PM
Foosh's Avatar
Same here on PZeros.
Old Dec 16, 2015 | 09:55 AM
DJS's Avatar
DJS
rain/ice/snow mode optimizes stability of the vehicle
to suit low-grip conditions. This helps the vehicle to
perform in a more gentle and controlled manner to
avoid skidding, allowing more confident progress
under adverse conditions.
Rain/ice/snow mode as part of the dsc uses:
modified slip-control system map for braking
decreased throttle progression
early transmission upshifts
softer damper map (adaptive damping variants)
diablomkii
May 3, 2016 01:04 PM
Winston Gilbert
Feb 11, 2016 02:32 PM
Swagger XC
Nov 22, 2015 12:55 AM
Rhett
Nov 21, 2015 10:23 PM
jcarey
US Western
Nov 20, 2015 07:32 AM
