Rear end oil leak
Old Aug 1, 2018 | 04:34 PM
Nati's Avatar
Originally Posted by Arne
Sorry but I do not know. Had my seal replaced with a new one last week. Unfortunately after driving some considerable (and fun) distance over the weekend, there still seems to be a minor leak present.
Car going in tomorrow for further "investigations".
Edit: car is checked for leaks and the diff and pinion seal is 100% sealed and thight. What I thought was still a leak, was most probabely some "leftover oilspill" from the previous leak, that had ended up at places which he (the mechanic) was not able to reach. Some active driving in curvy mountain roads in very warm temperatures made the "leftover oil spill" move from were it was collected.
I would keep an eye on that. Park over some clean cardboard.
Old Aug 2, 2018 | 01:16 AM
Arne's Avatar
Thanks for the advice Nati, and I will. However I did drive some 320 rather "enthusiastic" miles after the seal was changed over a 3 day periode up Mountains and through curvy fjords. I did deliberatly park on "easy to spot oil leak" surfaces during the whole trip and it was only during the two first days that I did find some oil drip. For the last part of the trip, and over night after I came home, there was no oil drip to be found. The mechanic also checked the oil level, and the diff was 100% full.
All signs indicates the leak has stopped and was caused by the pinion seal - but I certainly will keep an eye on it.
Old Aug 1, 2019 | 05:55 AM
NeilH's Avatar
Originally Posted by erind
I had the same issue as you in my ftype R. They replaced the differential under warranty. Known issue
Mine is in the dealers now having a gasket replaced- didn’t realise it was a known issue
Old Aug 1, 2019 | 06:35 PM
jaguny's Avatar
How many miles did you guys have when the leak(s) developed.
Old Aug 1, 2019 | 09:46 PM
lizzardo's Avatar
I noticed my pinion shaft seal leak at 32K miles.
Old Aug 1, 2019 | 11:52 PM
Arne's Avatar
I noticed mine at 18k km (~ 12k miles).
Old Aug 2, 2019 | 02:40 AM
NeilH's Avatar
19,000 on mine
Old Aug 3, 2019 | 10:16 PM
  #28
Nati's Avatar
Something like 25k
Old Aug 4, 2019 | 06:38 AM
jaguny's Avatar
I'm in the 20k range and probably should be on the lookout?
Old Aug 4, 2019 | 02:05 PM
  #30
Nati's Avatar
I'm sure it's still a low prevalence problem but I park over a clean cardboard box and started noticing oil spots. That's how I caught it.
Old Feb 16, 2020 | 03:55 PM
  #31
frank barone's Avatar
Hi Frank, my 16 s coupe, 32,000 miles, differential leak, appointment for repair2/24/20. Seems this is a issue. Let you know the remedy.
Old Feb 19, 2020 | 12:47 PM
  #32
Terrance39's Avatar
Mines leaked, but it was coming from the mount that holds the small actuator motor to the diff. Not a hard job to reseal at all. Just lower the exhaust and lower the rear brace and everything was easily accessible.
Old Jul 8, 2023 | 03:10 AM
  #33
Andi Jaguar G's Avatar
Hi,
is there anything to consider when disassembling the servomotor? Can you get it back together, or is there a specific installation method on this motor? My rear differential is also slightly damp, and would like to reseal this. I'm just a little concerned about the servomotor in case I have to disassemble that as well.
Thank you so much for all answers
Andi
Old Jul 8, 2023 | 02:28 PM
  #34
Terrance39's Avatar
Originally Posted by Andi Jaguar G
Hi,
Andi
No nothing special to look for. It's pretty straightforward.
Old Jul 9, 2023 | 09:54 AM
  #35
So you can rebuild the actuator Motor in any position? Even if the differential was rotated after removing the actuator Motor? At the moment it is not yet clear where the oil is coming from. Looks more like the case or the transition from the aculator motor to the case.
Old Jul 9, 2023 | 11:26 AM
  #36
Terrance39's Avatar
I'm not sure I understand what you mean. All I did was unbolt the motor from the diff. Remove the motor housing, reseal it and bolted the motor back up.
Old Jul 9, 2023 | 12:20 PM
  #37
Thank you, perfect...
Andi
Old Jul 9, 2023 | 02:07 PM
  #38
Hi,
What is the case sealed with? Standard sealant or are there original seals for sale?
Thank you
BR
Andi
Bacardi 151
Nov 10, 2015 11:26 AM
wotcham8
Jun 5, 2013 03:24 PM
Spedracr15
May 24, 2011 06:08 PM
