Rear spoiler - real user opinion
Old Mar 20, 2021 | 07:34 AM
datriani's Avatar
Default Rear spoiler - real user opinion
I am looking for opinions from people who HAVE installed this spoiler available on eBay. I really don’t care if you like the look or not, so please don’t chime in and detract from the purpose of this post. 😁
If you have bought and installed this spoiler, how’s the construction? Was it as easy to install as it looks, any issues? Do you regret installing it? Did you disable the factory raise at 70 mph?
https://www.ebay.com/itm/Carbon-Fibe....c100752.m1982
Old Mar 20, 2021 | 07:51 AM
Unhingd's Avatar
Do you plan on disabling the raising mechanism? If not, that sail will have an aerodynamic impact at over 70mph similar to that of mounting a billboard to the back of your car.
Old Mar 20, 2021 | 07:53 AM
Therock88's Avatar
I have not personally installed this spoiler, but looked at them and have seen quite a few posts out in the wild, and they seem to look good installed from the picture/posts I have seen. When I was looking at them, it does appear that you will need to drill 4 holes in the spoiler/decklid to secure it...FYI.
You WILL need to disable the the deployable feature on the spoiler if you have this wing on. It can be done with a toggle switch (which will kill it, but you will still get an error), and/or by using SDD software to code it out (which will remove the error message at about 102 MPH ish). There is also the box that comes with the JLR fixed wing, that (if you can find separately) will disable with no errors. And last and most brutal, is to cut the rods on the motor. All of this is documented in my Wing DIY if/when you are ready to do it.
Good luck!
DC
Old Mar 20, 2021 | 08:02 AM
datriani's Avatar
yes, I was planning on disabling that mechanism. I was thinking it would be funny (not really) if the spoiler just completely ripped off when hitting 120 mph.
Old Mar 20, 2021 | 08:08 AM
datriani's Avatar
Good luck!
DC
I was thinking of trying to find a used OEM spoiler panel and wrapping that in a carbon fiber wrap IF it doesn’t match my cars paint and drilling holes in that one. I’d like to keep the original spoiler as a spare incase I decide to go back. Thanks DC, I’ll check out that DIY write up.
Old Mar 20, 2021 | 05:41 PM
OzXFR's Avatar
There is another way to disable the rear spoiler, see here: https://www.jaguarforums.com/forum/f...5/#post1614196
Old Mar 20, 2021 | 06:09 PM
malbec's Avatar
It’s a wing.
The only thing it spoils is the looks.
Old Mar 20, 2021 | 06:41 PM
Therock88's Avatar
Does that still cause an error at 100+? Or do you know?. I think that is why some cut the rod, because the car still thinks it is raising the spoiler.. If this prevents the error, that is great!
DC
Old Mar 20, 2021 | 06:47 PM
OzXFR's Avatar
DC
Nup, the error message ("spoiler unavailable") still pops up at exactly 160 km/h / 100 mph.
You can get rid of the message in the usual way but the yellow warning triangle remains until you stop the car, turn it off, then restart.
Old Mar 20, 2021 | 07:52 PM
Therock88's Avatar
Got it...Thanks...I thought that might be the case. Unfortunately, when the error is triggered, the car is also limited to 135 MPH / 217 KMH and DSC is automatically switched on until it is cleared again.(Not that this may be a big issue for anyone).
So it appears there are three ways to disable without the error:
- Cut the drive rod on the motor
- Install the Fixed Wing Module
- Disable/remove accessory with SDD
DC
Enzo Valetti
Aug 13, 2020 06:54 PM
Jagsky
Oct 26, 2016 08:07 PM
BC XJS
Feb 19, 2016 09:45 PM
bluebird
Oct 10, 2014 12:55 AM
MiaXfsc
Jun 8, 2011 03:31 PM
