Removing Rear lettering
Old May 20, 2018 | 09:34 AM
SamtheSham's Avatar
Default Removing Rear lettering
This may have been covered in a previous thread, but I want to remove the lettering on my rear deck. I think someone suggested using dental floss and patience(which I am sometimes low on, patience, not floss). Is that correct?
Anything else I need to watch out for? I don't need to mess up a perfectly good F-Type just trying to make a great car a little better.
Old May 20, 2018 | 09:57 AM
Jkim24's Avatar
I used a heat gun and dental floss to remove my emblems. Keep in mind removing the cat will reveal 3 holes behind.
Old May 20, 2018 | 10:20 AM
Unhingd's Avatar
Be careful using that heat gun. Better to use a hair dryer.
Old May 20, 2018 | 10:21 AM
Jkim24's Avatar
it was on the lowest setting and far away from the car so no damage done 😊
Old May 20, 2018 | 10:22 AM
Unhingd's Avatar
You knew to do that, but some folks don't.
Old May 20, 2018 | 11:54 AM
Andy2017's Avatar
+1 - Absolutely! Heat guns can generate intense heat very quickly.
Just let the car sit out in the direct sun for 10-15 minutes. I removed my rear lettering with ease using dental floss.
Old May 20, 2018 | 11:58 AM
mark842's Avatar
I’ve removed badges on previous cars by pouring slightly cooled down water from a kettle over the badge then use dental floss. If it reveals 3 holes I wouldn’t bother though!
lizzardo's Avatar
I used a sunny day :-)
Old May 20, 2018 | 01:40 PM
El Gato's Avatar
So when the lettering is removed I assume their is some residual adhesive residue. Can it be cleaned up with something like goo gone or is there a preferred method?
Old May 20, 2018 | 01:48 PM
Unhingd's Avatar
GooGone is perfect, but wash the area thoroughly after you are done.
Old May 20, 2018 | 02:05 PM
lizzardo's Avatar
Is GooGone the naphtha based or the citrus based one? I was told by a detailer to not use the citrus based cleaners because they can actually remove paint. I think I softened up the residue with WD-40 and used acetone for the final cleanup.
Afterwards, I made sure to treat the paint with what I'd used elsewhere on the car.
Old May 20, 2018 | 03:56 PM
Unhingd's Avatar
GooGone is citrus based.It will take a long time to softened the clear coat, so wash with soap and water immediately after removing the adhesive. I have used it on all my de-lettered vehicles with no issue. I would strongly recommend against anything that is acetone based. That will eat right through the paint. My 2c.
Old May 20, 2018 | 04:23 PM
lizzardo's Avatar
I used the acetone really just for the final degreasing and had no ill effects. If the GooGone is washed off immediately afterwards, you'll avoid the issue I was warned against.
I think I used monofilament fishing line instead of dental floss as well. I guess I just need to be different.
Old May 20, 2018 | 04:26 PM
Unhingd's Avatar
I have used both. Both equally as effective. Waxed floss seems to work really well though.
Old May 20, 2018 | 05:23 PM
mlebofsky's Avatar
+1
Old May 20, 2018 | 06:32 PM
OzXFR's Avatar
For years now I have used eucalyptus oil (or tea tree oil) to remove the glue residue after de-badging. It dissolves the glue very nicely and cannot harm the clear coat or paint.
Old May 20, 2018 | 06:47 PM
SamtheSham's Avatar
That's what is great about this forum, 1 question, 3-4 equally good solutions. For me, sounds like waxed dental floss behind wife's hair dryer( I have already damaged a few things with my supercharged 3 spd. heat gun).
Follow up with Goo-B-Gone and heavy soap and water immediately with a lot of clean water afterward.
The 'Leaper' stays on, so no problem with the small holes.
Thx for all the solutions.
Old May 22, 2018 | 08:42 PM
Hayabusa's Avatar
She makes it look easy. I could mess it up easily.
Old May 23, 2018 | 04:51 AM
jaguny's Avatar
If she makes house calls, I'm having her remove all my badges. Even though, those nails will require a random orbital to remove the scratches. I'll deal with it.
Old May 23, 2018 | 07:11 AM
Sinjen's Avatar
Banned
Lol...queue 17 y/o me removing the badge from my first car and bubbling the paint.
