Replacement VAP Belt
Old Aug 4, 2023 | 01:10 PM
x152in512's Avatar
Default Replacement VAP Belt
Does anyone know where to get the 8DPK1470 belt other than Velocity? My car has been on the lift and in the bay at the shop for a few days now and I'm not getting any responses on the order I placed earlier in the week w/ rush shipping. Because the car is taking up space I tried looking for an alternative in the same length, rib pattern, etc. to give the shop their bay back. Closest I could find is an 8PK1470 but it's not double-sided. So I'm wondering if anyone was able to find the double-sided version. Much appreciated.
Old Aug 4, 2023 | 01:15 PM
Andi Jaguar G's Avatar
i think you have no opportunity for this belt, sorry...
Old Aug 5, 2023 | 02:50 PM
lizzardo's Avatar
I see from the VAP site that tuning services are closed from 8/1-10 for staff holiday so that may be affecting your order. I've got a double-sided 1461 with about 5200 miles on it if you're interested. I swapped it out when I discovered that VAP changed the specs for my car when the VIN break was updated, and am running a 1438 instead.
I don't know your year and model, but it's of no use to me. It's yours for the cost of shipping should you want it. If so, drop me a PM.
Old Aug 6, 2023 | 07:35 AM
Bierry's Avatar
I happened to use a crank pulley kit that chose to supply a smooth idler and thus uses a single-sided V belt, which opens up a world of size options. If time's pressing you could consider having the shop swap this idler to a standard smooth idler, then easily procure a perfectly-sized belt.
Smooth idler
Options of belt sizes to attain factory tensioner position. My particular car needed 1485mm length (kit supplied 1475mm length which was too taught and maxed the tensioner).
Dave Redline
Mar 27, 2021 09:21 PM
oldtvman
May 12, 2015 12:24 PM
steadk
Sep 28, 2014 04:03 PM
stephen11962
Apr 4, 2013 05:40 PM
