Replacing the 3" Rear Speakers With 5x7's
Hello again folks,
So it's pretty easy to do. You can actually just do a direct swap but I wanted to use an amp.
You should use an active LOC if you do this or you will push quite a bit of volts to your amp from the factory amp and most likely cause it to fault.
I have swapped every speaker in this car out. Direct swaps for the highs, mids and midbass.
Swapped and amped the subs with a custom cut, straight aluminum 1/8" plate, which wasn't really too hard. New subs are 8" and fit in the factory housing behind the seats.
And now swapped the 3" speakers which are above the subs, behind the seats, with 5x7s. Really an all around beast now and didn't even change the head unit.
Anyway, this is how it turned out for the 5x7s but I have vids of the other stuff on my youtube as well.
Maybe it will help some people out.
Cheers.
Cheers.
Very informative! The rear upper speakers are positioned at ear height and provide a nice surround effect only if tuned with correct polarity and speaker distance carefully measured to the L and R ear of the driver using a DSP.
But on a separate note I would worry about all your equipment being behind the seat. That's a lot of heat being generated with nowhere to go. You can use a thermal camera to check the temp during high volume music playing.
Plus I need the seat to all the way back against the rear wall to drive comfortably. All my equipment is in the trunk with 12V computer fans blowing on them for heat dissipation. I also didn't want to cut anything in case I needed to revert back to OEM if I were to ever sell the car.
Adjusting the sound level can be done pretty much with just gain and LOC level IMO. DSP is kind of unnecessary. I mean it's always nice but I don't find it critical in this situation.
To each their own of course.
darkeyesoflondon
Dec 27, 2024 09:35 AM
bart_redline99
Audio/Visual Electronics
Apr 23, 2012 05:07 PM
