Replacing license plate lights
Old Sep 17, 2020 | 01:17 AM
OnlySlightlyEvil's Avatar
Default Replacing license plate lights
Hey all, any tips for getting the plate light units out? I couldn’t do it - and cracked the cover of one. Does the whole black piece come out?
I have two new LED light units from China, as JLR stopped making them. Want to install!
Appreciate the help.
Old Sep 17, 2020 | 01:52 AM
JacksonvilleJag's Avatar
They are held in place by a spring clip located on the right end of the lamp assembly. I'm not home, so can't take any pictures right now.
Old Sep 17, 2020 | 09:18 AM
SS4PK's Avatar
Yes there is a spring clip, but you can't remove the light without removing the 3 or 4 the T25 TORX hidden under square plastic covers to remove the whole set-up including the trunk release button. Once you remove the T25, you can remove the lights depressing the spring and pushing them toward the "ground".
Old Sep 17, 2020 | 12:28 PM
Any tips to removing those covers and the unit, or is it pretty simple?
Old Sep 17, 2020 | 12:58 PM
SS4PK's Avatar
It's really easy, just use a small screw driver to remove the square covers, there is a tab on one side and then one on the opposite side, then just remove the TORX screws and it comes off.
bigreda357
Jan 20, 2023 11:40 AM
OnlySlightlyEvil
Jul 18, 2020 05:52 PM
luvinmyjagxf
Nov 20, 2017 10:00 AM
1 of 19
May 20, 2015 12:10 PM
chaddm55
May 11, 2013 03:39 PM
