RHD Headlights different then LHD?
Hello,
As the title, do anyone know if there is mechanical differences between the RHD headlights and the LHD headlights or if it's only a matter of programming? I Assume that they act different.
I need a passenger side headlight with black inside for my LHD 2015 beauty.
Hello,
From my quick review of TopIX, there doesn't appear to be any difference int he bog standard lights. You will just need to get them setup for X and Y height which you can do manually.
Took this snippet from TopIX:
HTH
My MY18 manual says "Adjustment is required when driving abroad if the vehicle is fitted with LED headlights. Move the lighting control from the AUTO position (5) to position (4) before driving. Position (4) is the "normal" headlights on position, one click past sidelights on. I guess that's to disable the AFS intelligence built in to the AUTO lighting position that adjusts for country, city, motorway, adverse weather modes.
The only adjustment to consider on the old HID system is that there is a setting in vehicle setup when using the auto hi-beam feature that you need to set for which side of the road you drive on.
there is definitely a difference in cutoff bw lhd and rhd - just drive up to a flat wall and you can easily see the shape of the beam as per pic above
on a bi-xenon/hid projector vehicle, there is no way to change the shape of the shield within the projector bowl that creates this cutoff, electronically within the car
as to Jag's website, they are only talking about temporarily driving in another market, not as fitted from factory
Hi, I'll revive this topic with the same question, but for the newer LED headlights with AFS function on the X152. Is there any HW difference, or different units, or are all the differences only in the SW (or can it adapt itself to the LHD car, for example, by a simple setting in the on-board computer)?
Thanks guys
Thanks guys
I asked around at my Jaguar specialist. He says there is a hardware difference and you have to have a RHD or a LHD set whatever you have to use.
I have the same problem. I have a F-type for the US market which isn’t allowed in the EU (I’m from the Netherlands). There is a lot headlights available for the UK market (LHD), but are not adaptable. I finally found a left and right headlight, but one of them is with cornering lights…… which also won’t work electronicaly. The search goes on. Of course I can buy a good left headlight today, but they quote me a €1000. I think that’s ridiculous.
The difference must be in the projector setup.
- UK market is RHD not LHD
- cornering lights (AFS) have 16 pins and one more control module than 11 pin "standard" lights
- 11pin lights are around 1000 EUR, 16pin lights are up to 2000 EUR
- be careful, there are two versions of both, with chrome or black housings
Sadly I don't know the physical difference.
Hey off subject BUT you got the head light apart!
Can you share how you did it? Oven baking at a certain temperature works on other lights but these late model ones seem to be harder to split.
Set up temperature about 270 C
Wow that is hot!
No damage to the shell at those temperatures? I am use to around 220F-250F on other head lights and 270C is 518F.
Surprised plastic can stand that.
No wonder we are having problems splitting the lens.
