right flap on the exhaust only opens 50%
Old May 29, 2022 | 10:49 AM
Andi Jaguar G's Avatar
Default right flap on the exhaust only opens 50%
Hello everyone,
can it damage the engine if the right flap on the exhaust only opens 50% due to a technical defect?
So not so good under full load, right? The flap jams and is difficult, the spring does not push the flap
completely open, I think only about 50-75%. What do you think?
Thank you so much
Andi
Old May 29, 2022 | 02:17 PM
sov211's Avatar
No, it will not damage the engine. Assuming that the vacuum line and connection is intact (if your model year has this), the the issue might be a simple one of lubrication of the operating mechanism at the flap.
Old May 30, 2022 | 02:07 AM
yes, the issue is a simple one of lubrication of the operating mechanism at the flap.
The flaps also squeak, and the right one runs much harder. Have already tried to attach high-heat lubricant
there in the inner tube. Not easy but possible. Have to try that again. The spring force just isn't quite enough to push the flap open to 100%.
BR
Andi
Old May 30, 2022 | 03:51 AM
dibbyandco's Avatar
I had a similar problem with one flap jammed completely open. You have to keep (gently) working at it to free it up.
Gasman2
Apr 15, 2022 03:57 PM
mushroom09
Sep 3, 2019 05:19 PM
simongulliver
Oct 21, 2015 05:03 AM
sacrider
Feb 25, 2010 11:35 PM
