Road Noise Reduction
Old Today | 03:23 AM
SteveGZ's Avatar
Default Road Noise Reduction
Hello
In keeping with the GT nature of the F Type we are planning a 9 day road trip to Ireland in a months time. While I have confidence in enjoying the car on the country roads, the motorway trip to get there could be hard work due to road noise.
On motorways the car sits at about 1700rpm. Opening or closing the exhaust valves (ASR Controller) make little difference. The fake engine noise (NGPTSQ) pipped through speakers has been disable. Tyres are P-Zeros.
Has anyone made a significant reduction in road noise from their F Type? Was it worth the effort? Or any recommendation for earplugs 😊
(probably should mention this is the coupe &#128522
Old Today | 05:03 AM
BruceTheQuail's Avatar
Unless you wanted to swap out the tyres for supersports which I thought ride very nicely as well, I'd just turn up the stereo, but in my experience it is best not to do that when your lovely wife is in the middle of a story.
Old Today | 07:10 AM
RoverJoe's Avatar
Community Influencer
I'd imagine it's worse because of the aftermarket cats you have on the car? I don't think they make crazy noise at a nice cruise like that.
Overall it's not a GT car, it's a sports car. You could pull paneling and add insulation, but I don't know if that would really give the desired results. One downside of aluminum unibody cars is they transmit noise in weird ways. You could be hearing powertrain noise transmitted through the body structure that would be tough to reduce.
Old Today | 07:28 AM
cwisenheimer's Avatar
Both you and your wife should simply wear earplugs. I wear them on long highway drives and they do wonders to reduce stress and fatigue.
Old Today | 07:53 AM
Thunder Dump's Avatar
The cats are definitely the issue. My MY23 is plenty quiet at cruising speed on the highway--even with the VAP valvetronic exhaust (valves closed). Absent swapping the cats, your only solution will be turning up the stereo or ear plugs.
Old Today | 09:56 AM
SteveGZ's Avatar
Thanks for all the comments. @cwisenheimer Yes I tend to use AirPods on long solo drives which make a big difference in noise cancelling mode. Its looking like earplugs for both of us is the way forward for the trip. If anyone hears a couple shouting at each other at a service station it might be us having forgot to take then out!
@Thunder Dump and @RoverJoe . Respectfully I am pretty sure the main source of noise while cruising is road noise. The different road surfaces can makes a big difference, and it sounds like road noise. Was looking for an easier solution than crossing the UK using only freshly laid smooth tarmac roads.
That said the F Type has less road noise than the 992 I have previously. But rather more than our Land Rover. Tinnitus is one of the curses of aging and not helped by spending hours in the Jag on a motorway.
Old Today | 10:28 AM
RoverJoe's Avatar
If it changes with road surfaces then yes it's going to be the junk Pirelli tires. Tough to compare the jag to a big Rover, as they are so much quieter inside, and yet we still have tire noise issues in the new ones using the 23" Pirelli tires.
Dennis07
Feb 12, 2020 03:09 AM
Reverend Sam
Jun 4, 2016 08:27 AM
JimC64
31
May 30, 2016 03:04 PM
Reverend Sam
Apr 27, 2012 10:17 AM
Currently Active Users Viewing This Thread: 7 (4 members and 3 guests)
