Rock stuck between window and door trim
Old Feb 11, 2019 | 12:17 AM
VeeDub's Avatar
Default Rock stuck between window and door trim
I have a rock that is stuck in the door window seal/weather stripping that is causing vertical scratches on my window if I open and close it. Does anyone have experience clearing debris on from this area? Is there an easy way to access and clean out this compartment? Thanks
Old Feb 11, 2019 | 02:43 AM
4x4uk's Avatar
Hi Take A look at this thread, this is a known issue with Ftypes
https://www.jaguarforums.com/forum/f...indows-166517/
Old Feb 11, 2019 | 09:31 PM
Unhingd's Avatar
I suspect you can use a thin strip of metal similar to a Slim Jim to clear that rock.
Old Feb 11, 2019 | 11:55 PM
VeeDub's Avatar
I followed the TSB to get the weather stripping removed. Used compressed air and a vacuum to get the inside seal. It fixed the problem. Now time to deal with the scratches. I recommend actually taken the weather stripping out as its super easy to take in and out. Fishing out the rock, I think is harder.
Jaguar XK8er
Aug 21, 2018 01:29 AM
Sean W
May 8, 2018 12:54 AM
Sean W
Aug 20, 2014 12:16 AM
jagjunky
Nov 11, 2013 10:45 PM
