SC pulley needed in So Cal
Old Feb 27, 2016 | 10:02 AM
Liamgo's Avatar
Default SC pulley needed in So Cal
Hello, I bought the pulley from Vmax and it doesn't fit. Their pulley is too small for my '15 R so it was bent upon installing and removing it many times. Long story short I need one ASAP. I don't care if it is for a V6S or a V8R, oem or not, but I need one. Anyone???
Old Feb 27, 2016 | 10:10 AM
Liamgo's Avatar
I'm in Ontario, CA
Old Feb 27, 2016 | 10:25 AM
Unhingd's Avatar
Originally Posted by Liamgo
I'm in Ontario, CA
The upper reduction pullies from any vendor are too small by a little bit. A bit of grinding is needed to polish the casting irregularities in the housing snout. Also, the pulley needs to be superheated before it is pressfit onto the shaft.
Pullies can be acquired from Eurotoys or Mina Gallery.
If you have a V-6 don't bother with the upper pulley...go straight to the crank pulley. There's only a 1.5 mm difference between the OEM and the reduction pulley.
Old Feb 27, 2016 | 10:40 AM
Liamgo's Avatar
Thanks, yea I'm aware of the grinding down part now (vendor never mentioned it) but unfortunately it's too late, pulley is now bent. I have an R and need any upper pulley still....
Old Feb 27, 2016 | 11:10 AM
Uk2usa's Avatar
Try http://http://www.ecutuninggroup.com/ they might have an OEM take off , they are in CA. Good luck!
Unhingd's Avatar
Try either of the two I mentioned above. They are both good to work with.
Old Feb 27, 2016 | 11:13 AM
Unhingd's Avatar
OEM take-offs usually get bent in the process.
Old Feb 27, 2016 | 11:29 AM
Liamgo's Avatar
I tried ETG just now, they won't sell a pulley on its own.
Old Feb 27, 2016 | 11:42 AM
Dremorg's Avatar
ETG also claims they don't do any grinding. They have a special tool to remove & install the pulleys.
Old Feb 27, 2016 | 11:47 AM
Uk2usa's Avatar
Well it was worth a try.
Old Feb 27, 2016 | 11:51 AM
Unhingd's Avatar
Here are your two options. I believe Eurotoys option is a better deal since it is less expensive and offers a test dummy pulley for test fitting before you install the real one.
http://www.eurotoysltd.com/catalog/p...133mlag9jr6ja7
http://www.minagallery.com/jaguar-f-...ulley-upgrade/
Old Feb 27, 2016 | 12:11 PM
Dremorg's Avatar
Old Feb 27, 2016 | 12:15 PM
Liamgo's Avatar
Yea it looks like I'm gonna have to order one if no one has one locally...
Old Feb 27, 2016 | 12:24 PM
Unhingd's Avatar
Mina is in the San Fernando Valley. Isn't that fairly local?
Old Feb 27, 2016 | 12:57 PM
Eurotoys's Avatar
Former Sponsor
I have a smaller pulley and a stock pulley in stock. My smaller pulleys come with a clearance gauge and instructions.
Mike
Old Feb 27, 2016 | 01:04 PM
Liamgo's Avatar
Mike
How can I reach you directly? I'm gonna have to place this order now
Old Feb 27, 2016 | 01:18 PM
Eurotoys's Avatar
Former Sponsor
Old Feb 27, 2016 | 01:21 PM
Jaronstoys's Avatar
Good job EuroToys !!! Now that is service
Old Feb 27, 2016 | 02:19 PM
Unhingd's Avatar
+1.
Old Feb 29, 2016 | 08:21 PM
Jaronstoys's Avatar
Hope it worked out for you
