Short Shifter, Anyone?
Old Jun 3, 2017 | 02:08 AM
  #221
Unhingd's Avatar
Originally Posted by lizzardo
I was driving today and realized the new throw has indeed become second nature. It was a crappy commute, but at least I was in the F-Type.
+2. The OEM throw was never 2nd nature. Always felt exaggerated.
Old Jun 4, 2017 | 01:04 PM
  #222
jfranks's Avatar
Originally Posted by Unhingd
Installation would take all of 10 minutes once the piece is fabricated. The gate plate would install in place of the boot. The upper stick would need to be modified for a decent appearance and a different knob would be needed since it is held on firmly with the boot collar. (note to self: finish P7 grille project first).
Please do a gated shifter. Can I throw money at you for this?
Old Jun 4, 2017 | 04:29 PM
  #223
Unhingd's Avatar
I'll have to do a mock-up of one before we get launched on fabricating a prototype. Given the design of the upper shifter shaft, that might have to be redesigned as well. Give me a few weeks to ponder this.
Old Jun 4, 2017 | 04:38 PM
  #224
lizzardo's Avatar
I've been thinking about this already.
Unless I'm mistaken, the one that will fit a 2016 will only fit a 2016, at least for LHD. Didn't they relocate the buttons to the driver's side of the shifter for 2017?
As for the shifter shaft, I'm not sure how that would all work. I only just got home from some errands, but may pull the boot up a little later and meditate on the dimensions.
Old Jun 4, 2017 | 05:31 PM
  #225
Unhingd's Avatar
The gate would simply be inserted where the boot bezel snaps into the console. As long as the boot part number remained the same, the two years (maybe even 2018) will be interchangeable.
Old Jun 4, 2017 | 07:33 PM
  #226
lizzardo's Avatar
The opening that has the boot and the swich panel is symmetrical, but the boot itself is not. The shifter shaft is almost 20mm in diameter in the upper section, but it hasn't tapered down to that yet at the point that is level with the boot mounting. The weight is below that level.
I took some pictures, but nothing that's not obvious to someone who lifts the boot on their own car.
If the short-shifter were made as one piece, all the way up to threads for a knob, that would make easier. It would also eliminate the vibration isolation dampers in the assembly.
More meditation is in order.
Old Jun 4, 2017 | 08:22 PM
  #227
Unhingd's Avatar
You want to leave that weight (damper) in the mix. It provides the nice heft to the feel. I believe, without it, the shifting would feel flimsy. Easy enough to test that theory.
Old Jun 5, 2017 | 12:05 AM
  #228
lizzardo's Avatar
As noted the weight is below the level where the gate would be. I don't think I'd even consider removing it because of what it adds to the feel.
Getting the buttons over to the left? That's something I'd consider.
Old Jun 5, 2017 | 08:37 PM
  #229
Stwsam's Avatar
Default image of excellence!
Brand of exclusivity!
Old Jun 6, 2017 | 06:44 PM
  #230
drbill's Avatar
"Unhingd Seal of Approval" Hmmm. Where have I heard that before?
I'm in the club!
Old Jun 12, 2017 | 12:20 PM
  #231
IcanDance2's Avatar
Default Unhingd Special
Thank you, Unhingd.
Old Jun 12, 2017 | 02:09 PM
  #232
lizzardo's Avatar
Originally Posted by IcanDance2
Thank you, Unhingd.
I got a cling too, but haven't "installed" it yet. I expect it will go easier than installing the shifter.
And yes, thanks Lance!
Old May 23, 2018 | 11:05 AM
  #233
Stuart@VelocityAP's Avatar
Default Unhingd Medicare Celebration Event
Jaguar F-Type Short Shift Kit
Okay boys & girls. Unhingd is getting old... so in order to help support our OAPs, we've decided to run a sale on these until the end of June, while supplies last. No coupon code required, just hop on there and order one!
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Old May 23, 2018 | 11:11 AM
  #234
DJS's Avatar
DJS
If you ask nicely, Unhinged may throw in a cigar too...
Old May 23, 2018 | 11:31 AM
  #235
lizzardo's Avatar
"Easy to install in just 30 minutes from inside the cabin"? I love mine and would not revert, but I did not find it to be that simple/easy, and did need to go under the car. I didn't drop the exhaust, so had a very tight and tricky manipulation to get the bolt in place.
Old May 23, 2018 | 12:27 PM
  #236
Unhingd's Avatar
Yes...in recognition of my June birthday, it's the Great Unhingd Medicare Celebration Event. (and it is an inside the cabin job only if you are Inspector Gadget and have 12 foot long arms). Supplies are limited and sale is good only if product is still available. This may be the last opportunity to get these at a decent price as we will probably not be ordering any more batches.
Old May 23, 2018 | 12:48 PM
  #237
lizzardo's Avatar
No-no Gadget arms ...
I did the job in the driveway with the right side of the car on ramps. If I hadn't had skills, years of experience, plenty of quality tools, and been really stubborn, I'd have ended up dropping the exhaust a bit. That'd have been quite a job with just ramps, stands, and a jack, so I said many "magic words" and persisted. Smaller hands would have helped rather a lot.
Nevertheless, it's a quality piece and greatly enhances the driving experience; more than I expected. It really does feel now the way it should have been from the factory.
If anyone is on the fence, I'd suggest getting in on it. If you or a friend doesn't have a lift, have a trusted local shop do the work.
Old May 23, 2018 | 06:36 PM
  #238
Unhingd's Avatar
Default Installation Instructions
For anyone ordering the short shifter, please print out the installation instructions attached to this post:
Old May 24, 2018 | 11:00 AM
  #239
Uncle Fishbits's Avatar
I had to hire a guy. He's a proper British car mechanic, but he hadn't seen many f-type's for obvious reasons because they're mostly still under warranty. He simply said that it was a challenge because no human fingers bend that way. Lol
Old Aug 25, 2018 | 03:29 PM
  #240
Unhingd's Avatar
Default Late Model Compatiblity
Shift rail T2R16381 was used on VINs through 40205, so the short-shift kit is guaranteed to work on those earlier MTs. That shift rail has been superceded by T2R23795 which has been used in production since VIN 40206 and is supplied as a replacement for ALL F-Type MTs. The change could be a simple casting, vendor, material, etc. change, or could incorporate a design change that renders the short-shifter incompatible.
F-Envy,
Unless someone else has already installed the short-shifter on a late model, there is no way of telling whether it is compatible with the later shifter rail without actually pulling out the OEM stick and comparing it with the short shift stick. What would be critical is the diameter of the pivot ball and the dimensions of the connecting eye.
I am wondering if Jag used this update to address the excessive throw. Before getting into this project, I suggest you measure the throw from gears 3 to 4. The early models had a 4+" stroke which is reduced to 3" with the short-shift kit.
