Should I replace any fluids on a 2016 with 12,000 miles?
Old Mar 20, 2021 | 09:29 AM
Whatsnext's Avatar
Default Should I replace any fluids on a 2016 with 12,000 miles?
I bought this in November with 11,800 on the clock and the dealer did the oil change (overfilled quite a bit but regardless). Since the car is almost 5 years old and still only 12,000 miles is there any other fluids I should consider changing soon just due to age. I live in AZ and my window of comfortable time in the garage will be nearing an end soon and if there is anything I can do or need to do I would prefer to do it soon.
Old Mar 20, 2021 | 09:39 AM
RGPV6S's Avatar
If the dealer or PO didn't do it already the brakes should be flushed.
Old Mar 20, 2021 | 10:35 AM
lizzardo's Avatar
The coolant might has a specified age, but it's ten years. Check your wiper blades as the dealers only seem to replace them when they're actually failing, at least when it's in the "free" maintenance window. Pollen filter is a two minute job to either replace or just check, so that's worth a look.
Since you just got it, I'd also recommend getting it in the air to look for any signs of leakage on the differential seals.
Old Mar 22, 2021 | 07:20 AM
Whatsnext's Avatar
I found the rear end leaking a week after I got the car. It was repaired by the dealer.
lobercio
Sep 13, 2017 01:58 AM
Snowmahn
Aug 16, 2017 09:52 PM
WhiteTardis
May 24, 2017 07:48 PM
Ubad2
Apr 20, 2017 11:53 AM
TXJagR
Feb 21, 2015 04:28 PM
